Polyline editing
2441
11-28-2016 10:50 PM
bharathreddy
Hi all,
   while applying edits to the polyline feature im getting the following (error:unable to complete operation index:15)
even after attributes and geometry are filling
here is the code im applying edits for point and line feature at the same time
var newGraphic = new esri.Graphic(ltp, null, attributes);
landusePointLayer.applyEdits([newGraphic]);
var newGraphicss= new esri.Graphic(kkk,null,attributes1);
landuseLineLayer.applyEdits([newGraphicss])
RobertScheitlin__GISP
sounds like there is something wrong with your geometry for the line then.
bharathreddy
Is there anything like apply edits works for only while drawing for me apply edits working when i draw a polyline but onclick i'm unable to apply edits
It is likely that you are just not forming a valid polyline in your code
bharathreddy
Hello Robert,
                        I am unable to do applyedits for the second time when i click on map  i am using  javascript version 3.18
<%@ Page Language="C#" AutoEventWireup="true" CodeFile="Default.aspx.cs" Inherits="_Default" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<link rel="stylesheet" href="https://js.arcgis.com/3.18/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.18/esri/css/esri.css">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>Landuse</title>
<style>
html, body
height: 100%;
width: 100%;
margin: 0;
padding: 0;
overflow: hidden;
.btn
background: #3f3f3f;
color: #fff;
font-family: Tahoma;
font-size: 11px;
height: 18px;
.lbl
color: #000;
font-size: 11px;
font-weight: 200;
#header
border: solid 2px #462d44;
background: #fff;
color: #444;
-moz-border-radius: 4px;
border-radius: 4px;
font-family: sans-serif;
font-size: 1.1em padding-left:20px;
#map
padding: 1px;
border: solid 2px #444;
border-radius: 4px;
#rightPane
border: none;
padding: 0;
width: 228px;
.templatePicker
</style>
<script src="https://js.arcgis.com/3.18/"></script>
<script type="text/javascript">
var map;
require([
"dojo/dom", "dojo/on",
"esri/map",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/toolbars/draw",
"esri/toolbars/edit",
"esri/graphic",
"esri/config",
"esri/tasks/QueryTask",
"esri/tasks/query",
"esri/Color",
"esri/geometry/Polyline",
"esri/geometry/Point",
"esri/layers/FeatureLayer",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/SimpleFillSymbol",
"esri/symbols/CartographicLineSymbol",
"esri/dijit/editing/TemplatePicker",
"dojo/_base/array",
"dojo/_base/event",
"dojo/_base/lang",
"dojo/parser",
"dijit/registry",
"dojo/_base/Color",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane",
"dijit/form/Button", "dojo/domReady!"
], function (
dom, on, Map, ArcGISDynamicMapServiceLayer, Draw, Edit, Graphic, esriConfig, QueryTask, Query, Color, Polyline, Point,
FeatureLayer,
SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, CartographicLineSymbol,
TemplatePicker,
arrayUtils, event, lang, parser, registry, Color
parser.parse();
// refer to "Using the Proxy Page" for more information: https://developers.arcgis.com/javascript/3/jshelp/ags_proxy.html
esriConfig.defaults.io.proxyUrl = "/proxy/";
// This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications.
esriConfig.defaults.geometryService = new esri.tasks.GeometryService("https://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
map = new Map("map", {
center: [-83.244, 42.581],
zoom: 15
var executeQueryTask;
var line;
var lineSymbol;
var dynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer("http://localhost:6080/arcgis/rest/services/edit/MapServer");
map.addLayer(dynamicMapServiceLayer);
//initialize query task
var queryTask = new QueryTask("http://localhost:6080/ArcGIS/rest/services/edit/MapServer/20");
//initialize query
var query = new Query();
query.returnGeometry = true;
query.outFields = ["LTP_ID", "OBJECTID"];
symbol = new SimpleMarkerSymbol();
symbol.setStyle(SimpleMarkerSymbol.STYLE_SQUARE);
symbol.setSize(10);
symbol.setColor(new Color([255, 255, 0, 0.5]));
on(dom.byId("execute"), "click", execute);
on(dom.byId("ltext"), "click", ltext);
var landusePointLayer = new FeatureLayer("http://localhost:6080/arcgis/rest/services/edit/FeatureServer/20", {
mode: FeatureLayer.MODE_SNAPSHOT,
outFields: ["*"]
var landuseLineLayer = new FeatureLayer("http://localhost:6080/arcgis/rest/services/edit/FeatureServer/34", {
outFields: ["*"]
// map.on("layers-add-result",setupEditor);
map.addLayers([landusePointLayer, landuseLineLayer]);
function execute() {
debugger;
query.text = dom.byId("stateName").value;
queryTask.execute(query, showResults);
function showResults(featureSet) {
debugger;
map.graphics.clear();
//Performance enhancer - assign featureSet array to a single variable.
var resultFeatures = featureSet.features;
//Loop through each feature returned
for (var i = 0, il = resultFeatures.length; i < il; i++) {
//Get the current feature from the featureSet.
//Feature is a graphic
var graphic = resultFeatures;
graphic.setSymbol(symbol);
//Set the infoTemplate.
//graphic.setInfoTemplate(infoTemplate);
//Add graphic to the map graphics layer.
map.graphics.add(graphic);
if (graphic.geometry.type === 'point') {
map.centerAndZoom(graphic.geometry, 0.001);
function ltext() {
debugger;
line = new Polyline(map.spatialReference);
lineSymbol = new CartographicLineSymbol(
CartographicLineSymbol.STYLE_SOLID,
new Color([255, 0, 0]), 10,
CartographicLineSymbol.CAP_ROUND,
CartographicLineSymbol.JOIN_MITER, 5
pointSymbol = new SimpleMarkerSymbol().setColor(new Color([255, 0, 0, 0.5]));
dojo.connect(map, "onClick", addPt);
function addPt(e) {
debugger;
var pathCount = line.paths.length;
console.log(pathCount);
// console.log(e.mapPoint.y);
// console.log(e.mapPoint.x);
if (pathCount == 0) {
var point1 = new Point(218966.696, 1173294.233, map.spatialReference);
var point2 = new Point(e.mapPoint.x, e.mapPoint.y, map.spatialReference);
line.addPath([point1, point2]);
map.graphics.add(new Graphic(point1, pointSymbol));
map.graphics.add(new Graphic(point2, pointSymbol));
map.graphics.add(new Graphic(line, lineSymbol));
var template = landusePointLayer.templates[0];
var newAttributes = lang.mixin({}, template.prototype.attributes);
var newGraphic = new Graphic(point2, null, newAttributes);
landusePointLayer.applyEdits([newGraphic], null, null);
var template1 = landuseLineLayer.templates[0];
var newAttributes = lang.mixin({}, template1.prototype.attributes);
var newGraphicss = new Graphic(line, null, newAttributes);
landuseLineLayer.applyEdits([newGraphicss], null, null);
else {
var getX = line.paths[pathCount - 1][line.paths[pathCount - 1].length - 1][0],
getY = line.paths[pathCount - 1][line.paths[pathCount - 1].length - 1][1],
mapPointX = e.mapPoint.x, mapPointY = e.mapPoint.y;
var pointS = new Point(getX, getY, map.spatialReference);
var pointD = new Point(mapPointX, mapPointY, map.spatialReference);
line.addPath([pointS, pointD]);
map.graphics.add(new Graphic(pointS, pointSymbol));
map.graphics.add(new Graphic(pointD, pointSymbol));
map.graphics.add(new Graphic(line, pointSymbol));
var template1 = landusePointLayer.templates[0];
var newGraphic = new Graphic(pointD, null, newAttributes);
var newAttributessss = lang.mixin({}, template1.prototype.attributes);
var newGraphicss = new Graphic(line, null, newAttributessss);
</script>
</head>
<body class="claro">
<div style="height: 30px; border: solid 1px; border-color: #e4e4e4; width: 100%;
background: #f0ebff">
Header
</div>
<div style="height: 25px; border: solid 1px; border-color: #e4e4e4; width: 100%;
background: #d2d2d2; text-align: center">
ToolBar
</div>
<div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="gutters:true, design:'headline'"
style="width: 100%; height: 100%;">
<div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
</div>
<div id="rightPane" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'right'">
<span class="lbl">Enter Value :</span>
<input type="text" id="stateName" >
<input id="execute" type="button" value="Get Details">
<input id="ltext" type="button" value="Start LT Ext" />
</div>
</div>
</body>
</html>
