points and coordinates
1146
07-28-2013 08:44 AM
MartinAshmore
I am trying to create a really simple map which does the following:
1. User clicks on the map to place a point. This point is not recorded, but a symbol needs to be displayed.
2. The coordinates of the point are displayed in form fields beneath the map. I want to get the information from these fields later using a standard javascript getElementById.
I'm fine with creating the map and getting my map layer etc from the samples, and I can see how to create a pop up showing the coordinates (unfortunately I don't want to achieve this with a popup). But I'm getting confused about which ?classes? I need to use to do this from the api: screenpoint, point.
Any pointers about how to do what seems like a simple thing would be greatly appreciated.
The closest sample I have been able to find is:
<http://developers.arcgis.com/en/javascript/samples/widget_measurement/>
In this sample the location tool does what I require, but I want the results to be placed into fields outside the map.
Just to be clear I don't want a pop up box, which all the samples that do what I want seem to use.
Martin
JakeSkinner
Esri Esteemed Contributor
Hi Martin,
Take a look at this fiddle example.  Is this along the lines of what you are looking for?
MartinAshmore
Hi Jake,
That is exactly what i'm looking for.
Martin
