Point does not add on map using Coordinate Conversion Widget
1886
08-23-2022 12:15 AM
Vakhtang_Zubiashvili
Hi guys,
I  am using Coordinate Conversion Widget to see coordinates on map. When clicking on map, i can see coordinates in widget form, but point graphic does not add to the map and i can not copy coordinates in widget form.
I tried to add widget in different places in Require Script , but no succcess.
Who can help 😄
Okay guys,
I fixed it, problem was in my custom widget code, so i changed two lines and it works now.
Cheers!
Okay guys,
Cheers!
Noah-Sager
Great news, feel free to mark the post as solved, even if you provided your own solution.
