Point Clustering with WKID:4326
2102
09-26-2013 09:27 AM
AndrewDavis
I am working with the point clustering example: http://developers.arcgis.com/en/javascript/samples/layers_point_clustering/
and have been able to get it to work nicely with a WebMercator map locally.
I have to deploy an instance where it will be plotted on top of a map with a tiled basemap (wkid:4326).
I have gone through the code and made sure that all of my wkid entries were 4326.
I am able to get my cluster graphics to show on that map, but they all plot inside that hole in the bottom of the ocean (0 by 0);.
Is there anyone who is using clustering on a wkid 4326 map?
Andy..
ZachLiu1
Have you checked the map.spatialReference to see if the whole map is really displayed in WKID 4326?
ZachLiu1
AndrewDavis
Yes, that is what I am having fun with right now.
The map spatial ref is in 4326.
The tiled map service (my basemap) is in 4326 on my server
Inside the 'clusterLayer' (firebug)
  • the '_clusterData' collection of objects are showing decimal degree coordinates.
  • the clusterLayer spatialReference is set to wkid 4326
... Found it...
Inside the 'ClusterLayer.js' script on line #64 there is a call to spatial reference "102100"...  Once I changed that I had a bonanza..
Thanks for your reply and I appreciate your help.
Things are always clearer in the morning...
Andy
ZachLiu1
Usually when features cluster at around (0, 0) it means you put lat, lng points on a projected coordinate system cause the numbers are too small. Glad to help.:)
