Placing Info Window at xmax,ymax of Feature Extent
2005
6
01-15-2018 01:26 PM
ThomasMetos1
I am attempting to place Info windows at the [xmax,ymax] of a feature extent. I have attempted using the following code.
var extent = new esri.geometry.Extent(feature.geometry.getExtent());
 var xmax = extent.xmax;
 var ymax = extent.ymax;
 var location = new Point([xmax,ymax]);
 map.infoWindow.show(location);
The labels do not appear.
I extracted the xmax and ymax values as discussed in This thread.
When I replace:
with...
map.infoWindow.show(feature.geometry.getCentroid());
The labels appear in the center of the feature as they should. So is something incorrect about the way I create the point? I have attempted most formats in The Point Documentation, with no luck. Any ideas where I should go from here?
Thanks
ThomasMetos1
I converted the x,y coordinates of the feature extent to latitude and longitude using
webMercatorUtils.xyToLngLat(xmax,ymax)
which solved the problem!
RobertScheitlin__GISP
Thomas,
   is the extents maxy and maxx in the maps current viewable extent?
ThomasMetos1
Yes they are.
Thomas,
   Are you have the require to esri/Geometry/Point in your require list right? Does your browsers console show any errors?
ThomasMetos1
I do have it in the require list. I am not getting any console errors either.
Very strange. Can you build a small sample that has this issue for testing?
ThomasMetos1
