PictureMarkerSymbol vanishes on tilting - Possible Bug
3282
12-10-2015 03:27 AM
omega_cancer
I am using following code in sandbox.
There is a picturemarkersymbol which displays ESRI logo. These snaps are taken in series
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>3D Graphics - 4.0beta2</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.0beta2/esri/css/main.css">
  <script src="https://js.arcgis.com/4.0beta2/"></script>
  <style>
    html,
    body {
      padding: 0;
      margin: 0;
  </style>
  <script>
    require([
        "esri/Map",
        "esri/views/SceneView",
        "esri/Camera",
        "esri/layers/GraphicsLayer",
        "esri/Graphic",
        "esri/geometry/Point",
        "esri/geometry/Polyline",
        "esri/geometry/Polygon",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/symbols/PictureMarkerSymbol",
        "dojo/domReady!"
      function(
        Map, SceneView, Camera, GraphicsLayer,
        Graphic, Point, Polyline, Polygon,
        SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, PictureMarkerSymbol
        var map = new Map({
          basemap: "hybrid"
        var view = new SceneView({
          container: "viewDiv",
          map: map,
          camera: new Camera({
            position: new Point({
              x: -0.17746710975334712,
              y: 51.44543992422466,
              z: 1266.7049653716385
            heading: 0.34445102566290225,
            tilt: 82.95536300536367
         * Add graphics layer
        var graphicsLayer = new GraphicsLayer();
        map.add(graphicsLayer);
         * Add a 3D point graphic
        // London
        var point = new Point({
            x: -0.178,
            y: 51.48791,
            z: 1000
          markerSymbol = new PictureMarkerSymbol({
            //url: "https://developers.arcgis.com/javascript/graphics/tailcoat/integration-hexicon.png"
            url: "https://developers.arcgis.com/javascript/graphics/tailcoat/logo-esri-footer.jpg",
            width: 250,
            height: 250
        var pointGraphic = new Graphic({
          geometry: point,
          symbol: markerSymbol
        graphicsLayer.add(pointGraphic);
         * Add a 3D polyline graphic
        var polyline = new Polyline([
            [-0.178, 51.48791, 0],
            [-0.178, 51.48791, 1000]
          lineSymbol = new SimpleLineSymbol({
            color: [226, 119, 40],
            width: 4
        var polylineGraphic = new Graphic({
          geometry: polyline,
          symbol: lineSymbol
        graphicsLayer.add(polylineGraphic);
         * Add a 3D polygon graphic
        var polygon = new Polygon([
            [-0.184, 51.48391, 400],
            [-0.184, 51.49091, 500],
            [-0.172, 51.49091, 500],
            [-0.172, 51.48391, 400],
          fillSymbol = new SimpleFillSymbol({
            color: [227, 139, 79, 0.8],
            outline: new SimpleLineSymbol({
              color: [255, 255, 255],
              width: 1
        var polygonGraphic = new Graphic({
          geometry: polygon,
          symbol: fillSymbol
        graphicsLayer.add(polygonGraphic);
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
When I tilt it vanishes
When I change camera It comes back
Now it vanishes again
upon zooming out it comes back again
when I tilt down it appears
down and vanish it goes
comes again
same goes when I use the picturemarkersymbol with a local path.
RobertScheitlin__GISP
Abdul,
   I can confirm that I see the same issue.
