PictureMarkerSymbol custom anchor point
1401
12-07-2010 05:41 AM
BabbageOcelot
Hello JS developers,
I cant find any guidance on the following, so feel free to point me to some links.
I'm looking for a way to set the relative position of a graphic, specifically a PictureMarkerSymbol, to its underlying point geometry; this is necessary to use the pushpin style markers prevalent these days.
As far as I can tell, the picture is rendered with its centre on the geometry point, which isn't going to be correct for a pushpin with a point on the bottom!
I suppose creating a graphic with transparent padding is one solution, but that will cause pain when the user clicks on the sizeable transparent portion expecting [a different operation].
Any ideas?
Regards,
Ben.
DavidVernau
Hi Ben,
I believe you can use the xoffset and yoffset properties of the parent MarkerSymbol class.
Cheers
