PictureFillSymbol doesn't appear with FeatureLayer
1010
04-23-2025 08:30 PM
WoraminSat
I have an issue with Polygon feature with PictureFillSymbol such as striped , dotted when using FeatureLayer.
(The picture below I tested from ArcGIS Online Map Viewer but got the same issues in my development environment)
This is the correct displayed example when I add whole map service as MapImageLayer. PictureFillSymbol with striped or dotted can display correctedly
However, when I add only sublayer as FeatureLayer , the polygon with PictureFillSymbol with striped or dotted pattern doesn't appear correctly
Do I have to set any properties to make FeatureLayer display correctly? Please help me resolved this.
Edvinas_S
If you go to the URL of the sublayer, does it have "Drawing Info" defined? Maybe it's only defined in the parent layer.
I found a sublayer in esri samples: https://sampleserver6.arcgisonline.com/arcgis/rest/services/PoolPermits/MapServer/0 If I add it to a map, it's symbols match the Drawing Info.
WoraminSat
I checked a sublayer in my map services. There are drawing info that has a diagonal (striped) or dotted pattern
