Picture Marker not visible in print
5197
12
02-17-2023 07:59 AM
ADITYAKUMAR1
Hi ,
  I have defined a picture marker which is properly coming on the map.
stopSymbol = {
type: "picture-marker",
url: _globalGISUrl + "Images/marker/inspection-map-markers-no-status.png",
width: "22px",
height: "22px"
But when I try to take a print of the picture marker is not available in the print pdf.
ADITYAKUMAR1_0-1676649340122.pngADITYAKUMAR1_1-1676649359266.png I am working with JavaScript 4. At some discussion I saw a similar problem where it was told to check if the picture marker is accessible to the print but I am not sure how to check that.
Aditya Kumar
ADITYAKUMAR1
@LefterisKoumis Thanks for writing.  I just cross-checked and found the url is behaving as expected. Even when I pass the complete url as you wrote, its showing on the map but not coming on the print.
LefterisKoumis
Just one more thing to try. Paste the url in an incognito window to see if you still see the png.
ADITYAKUMAR1
@LefterisKoumis yes I can see the png file.
