Picture Fill Symbol URL?
9733
14
01-22-2015 10:24 AM
DavidColey
MVP Frequent Contributor
Hi-
Does anyone know the url(s) for picture fill symbols?
David
DavidColey
Thanks Tim - That's exactly what  I am doing here:
var newFirmSym = new SimpleFillSymbol(SimpleFillSymbol.STYLE_FORWARD_DIAGONAL, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0,25,255]), 3), new Color([255,255,0,0.5]));
but the FORWARD_DIAGONAL keeps rendering default black . .  .
TimWitt2
You are right, it doesn't work for me either.
DavidColey
Thanks, I thought I was going crazy.  I was hoping to not have to render it in the mxd, but I may not have a choice....
KenBuja
MVP Esteemed Contributor
Take a look a this discussion that goes into why you can't apply a color to the different fill patterns.
The hatch patterns cannot be altered via the api because they are images.
Only STYLE_SOLID will use the color provided. STYLE_SOLID and STYLE_NULL are the only "pure" esri/symbol/SimpleFillSymbol(s).
All the other fill options like STYLE_BACKWARD_DIAGONAL, are actually esri/symbol/PictureFillSymbol(s), which use images that are included in the api http://js.arcgis.com/3.7/js/esri/images/symbol/sfs/vertical.png.
The solution, work-around or what have you is to use esri/symbol/PictureFillSymbol with your own custom images.
DavidColey
Thanks Ken, I was looking for that discussion and couldn't find it.  I would agree with your work around re the PictureFill, but it also looks like if you reference this js
https://raw.githubusercontent.com/Chaussette/esri.symbol.FillPattern/master/esri.symbol.FillPattern....
that it overrides the default behavior.. either way thanks to you both for help-
David
