Perform query based in existing map graphics
1628
6
11-28-2011 07:41 AM
TiagoRibeiro
Hi there,
I'm trying to create a function that performs a query on the map based in the current map.graphics.
Is there an easy way to add map.graphics to the geometry parameter, besides going trough the map.graphics.graphics array to find the extents?
Thanks
HemingZhu
Hi there,
Thanks
geometries = esri.getGeometries(map.graphics);
geometryService.union(geometries, function(geometry){
        query.geometry =geometry;
TiagoRibeiro
Thanks for your response, but I accomplished the some thing (I think) using:
esri.graphicsExtent(map.graphics.graphics)
It seems to work fine, but can you tell me the difference between this solutions and yours?
HemingZhu
your approach used the extent of map.graphics.graphics as query.geometry while mine merged map.graphics.graphics into one geometry and used that geometry as query.geometry.
TiagoRibeiro
Ok, I understood that part, but I was wondering what's the best approach, and if the final result will be the same.
HemingZhu
The result may or may not be the same. For example a point which may be within the extend of a polygon may actually outside that polygon.
TiagoRibeiro
That's what I thought. As I see it for better performance use the extents, because you don't need the geometry service, and for accuracy use the join (right?).
By the way, is there a way to perform geometry operations (buffer, intersects, joins, etc) on the client side, without using the geometry services?
