Passing in Field Name of evt.graphic.attributes
4093
06-29-2015 12:07 PM
KeithAnderson
Folks
I am using
Layer.on("Click", function (evt){
var testval = evt.graphic.attributes.ADDRESS
to return the Feature value of the "ADDRESS" field.
testval results are fine.
My issue is I need to pass in a different Field each time a new FeatureLayer is activated.
I have the name of the Field prior to the on Click event.
What is the syntax....
fld = "NAME";
var testval = "evt.graphic.attributes." + fld;
Alternative ideas welcome.
Keith
RobertScheitlin__GISP
Keith,
  Try:
fld = "NAME";
var testval = evt.graphic.attributes[fld];
Keith,
  Try:
fld = "NAME";
KeithAnderson
Thank you Robert!
