pass an object to an evt
961
08-15-2013 04:56 AM
DavidKearney1
Hi, we're occasional users of the JSAPI  using an older API (2.1). We're trying to create a page which does 2 things, first using a mark point function, which  gives us a pop up with a symbol for the point and it gets the coords for us (onClick).
function markpoint(evt)
We want to pass this through to an identify function to identify the map at these cords using function 'doIdentify(evt)'
We get the datagrid with no data, so it's not taking the marked point....
The text below is where it gets to: Anyone see any glaring errors?
function doIdentify(evt) {
            //map.graphics.clear();
            identifyParams.geometry = evt;
            identifyParams.mapExtent = map.extent;
            identifyTask.execute(identifyParams, function(idResults) {addToMap(idResults, evt); });
_
bit more of the script for reference... or luck_____________________________________________________
   dojo.connect(map.infoWindow, "onShow", function() {
                dijit.byId("tabs").resize();
        dojo.connect(map, "onClick", markpoint);
function markpoint(evt) {
        var point = evt.mapPoint;
        var symbol = new esri.symbol.SimpleMarkerSymbol().setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_POINT);
        var graphic = new esri.Graphic(point, symbol);
        var outSR = new esri.SpatialReference({ wkid: 27700});
        map.graphics.add(graphic);
        gsvc.project([ point ], outSR, function(projectedPoints) {
          pt = projectedPoints[0];
          graphic.setInfoTemplate(new esri.InfoTemplate("Coordinates",
            "<p> X: " + pt.x +
            "<br/> Y: " + pt.y +
            "</p>"  +
            "<input type='button' value='Confirm Point' onClick='identifypoint(map);' />" +
            "<div id='latlong'></div>"));
          map.infoWindow
            .setTitle(graphic.getTitle())
            .setContent(graphic.getContent())
            .show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
function identifypoint(map){
identifyTask = new esri.tasks.IdentifyTask("http://bl-arcgis-1/ArcGIS/rest/services/CRM/MapServer");
            identifyParams = new esri.tasks.IdentifyParameters();
            identifyParams.tolerance = 3;
            identifyParams.returnGeometry = true;
            identifyParams.layerIds = [1, 2, 3, 4];
            identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL;
            identifyParams.width = map.width;
            identifyParams.height = map.height;
            map.infoWindow.resize(415, 200);
            map.infoWindow.setContent(dijit.byId("tabs").domNode);
            map.infoWindow.setTitle("Identify Results");
  symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.5]));
doIdentify();
hello();
function addToMap(idResults, evt){
//alert("hello");
            layer1results = { displayFieldName: null, features: [] };
            layer2results = { displayFieldName: null, features: [] };
            layer3results = { displayFieldName: null, features: [] };
            layer4results = { displayFieldName: null, features: [] };
            for (var i = 0, il = idResults.length; i < il; i++) {
                var idResult = idResults;
        if (idResult.layerId === 1) {
                    if (!layer1results.displayFieldName) { layer1results.displayFieldName = idResult.displayFieldName };
                    layer1results.features.push(idResult.feature);
                } else if (idResult.layerId === 2) {
                    if (!layer2results.displayFieldName) { layer2results.displayFieldName = idResult.displayFieldName };
                    layer2results.features.push(idResult.feature);
                } else if (idResult.layerId === 3) {
                    if (!layer3results.displayFieldName) { layer3results.displayFieldName = idResult.displayFieldName };
                    layer3results.features.push(idResult.feature);
                } else if (idResult.layerId === 4) {
                    if (!layer4results.displayFieldName) { layer4results.displayFieldName = idResult.displayFieldName };
                    layer4results.features.push(idResult.feature);
KenBuja
MVP Esteemed Contributor
Yes, that's they way I pass in the evt to a function
identifyTask.execute(identifyParams, function (results) { populateTC(results, evt); });
How are you building the datagrid? Does this thread give you any ideas?
And if you're going to post code, please wrap it in the
 block (the # button above)
DavidKearney1
Thanks Ken
Tried re-writing this but using a standard popup for the identify instead of datagrid, this time using the latest API.
Getting the same problem - so I posted this separately, apologies in advance, I didn't use the CODE button... I know for future though (using the forums's confusing me as much as the API.....)
Cheers
