OverviewMap and Scalebar with dynamicMapServiceLayer
3622
09-23-2013 11:19 AM
by Anonymous User
Not applicable
Original User: [email protected]
Original Date: 2013-09-23T12:19:12-0600
Hello,
I've recently started with the developement of a small webmap using Java script.
For now I just concentrate on some basic features like adding a scalebar and an overview map.
I've search for some examples for scalebar and overviewmap and put them together:
    <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/esri/css/esri.css">
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
      #map{padding:0;}
    </style>
    <script src="http://js.arcgis.com/3.6/"></script>
    <script>
      var map;
      require([
        "esri/map", "esri/dijit/Scalebar", "esri/dijit/OverviewMap",
        "dojo/parser",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!",
      ], function(
        Map, Scalebar, OverviewMap,
        parser
        parser.parse();
        map = new Map("map", {
          basemap: "topo",
          center: [-116.093, 34.218],
          zoom: 7
        var scalebar = new Scalebar({
          map: map,
          // "dual" displays both miles and kilmometers
          // "english" is the default, which displays miles
          // use "metric" for kilometers
          scalebarUnit: "dual"
        var overviewMapDijit = new OverviewMap({
          map: map,
          visible: true
        overviewMapDijit.startup();
    </script>
  </head>
Now I want to replace the basemap with a dynamicMapServicelayer but it doesn't work. The code for using a dynamicMapService is the following...I've tried out so many combination, but with no success.
    <script>
      dojo.require("esri.map");
      var map;
      function init() {
        map = new esri.Map("mapDiv", {
        //  sliderOrientation: "horizontal"
        var imageParameters = new esri.layers.ImageParameters();
        imageParameters.format = "jpeg";  //set the image type to PNG24, note default is PNG8.
        //Takes a URL to a non cached map service.
        var dynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Population_World/MapServer", {
          "opacity":1,
          "imageParameters":imageParameters
        map.addLayer(dynamicMapServiceLayer);
      dojo.ready(init);
    </script>
It would be really nice, if somebody would help me. In addition I have another question: For which purpose I need the "function init()" and "dojo.ready(init);"? I've read the documentation, but this didn't help me.
Thanks in advance,
Dominik
by Anonymous User
Not applicable
Original User: JSkinn3
Hi Dominik,
Are you looking to overlay the dynamic layer onto your basemap?  Here's an example on how to do this:
<!DOCTYPE html>
<html>
<head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
    <title>Simple Map</title>
    <style>
      #map{
          height:100%;
    </style>
    <script>
      var map;
      require([
        "esri/map", "esri/dijit/Scalebar", "esri/dijit/OverviewMap", "esri/layers/ArcGISDynamicMapServiceLayer",
        "dojo/parser",
      ], function(
        Map, Scalebar, OverviewMap, ArcGISDynamicMapServiceLayer,
        parser
        parser.parse();
          basemap: "topo",
          zoom: 7
        var dynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Population_World/MapServer");
          map: map,
          map: map,
          visible: true
    </script>
  </head>
<body></body>
</html>
Your first example is using the new Asynchronous Module Definition(AMD), while the second is using the Legacy Module.  I would recommend learning AMD as this is the direction the JS API is going.  With AMD you do not need to call the init function.
DominikSchlarmann
Hi Jake,
Thanks for clarification and of course for your answer!
Later on I want to use basemaps as wel to give users the option to switch between several basemaps.
I plan to use this basemap gallery: https://developers.arcgis.com/en/javascript/jssamples/widget_basemap.html. If it's not to "outrageous", you can add this to your previous example :rolleyes: ?
Regarding your example code, unfortunately I get the following error using chrome's developers tools:
http://imgur.com/NMaQv12
Uncaught TypeError: Cannot read property 'id' of null
Any ideas?
Thanks for your help:),
Dominik
by Anonymous User
Not applicable
Original User: Suba_Krishnan
Hi Dominik,
Please add the div in html and it should work 🙂
  <body>
    <div id="map"></div>
  </body>
Suba
