OverView map floats over corner of page not corner of map
1613
09-28-2010 03:25 AM
JamesB
I am following http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jssamples/map_overviewmap.html
And the overview map functions properly but it appears in the top right hand corner of the entire web page, not the map. This happens in IE, Chrome and FireFox.  Has anyone come across this before?
One thing is I am not using the dojotype dijit.layout.* tags, I have my own div I am styling directly. But it must be possible to get this sample working without such tags?
James
JamesB
Looking at that sample, if I take the dojo markup out so the body tag goes:
  <body class="claro">
    <div style="width: 400px; height: 400px; margin: 0;">
      <div id="map">
      </div>
    </div>
  </body>
The overview box still appears over the top right of the page not the map. Is this how it's meant to work?
HeribertoMantilla_Santamaría
If you need put your OverviewMap in Special Div check out this example http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/map_overviewma...
Only add
// add the overview map
overviewMapDijit = new esri.dijit.OverviewMap({
    map: map
}, dojo.byId('overviewMapDiv'));
KellyHutchins
Esri Notable Contributor
You can resolve this issue by adding "position:relative" to the map div's style. This is necessary because the overview map is absolutely positioned and its containing block will be the closest positioned ancestor element. Setting the position of the map's div to relative will make it the overview map's container. Details on this behavior can be found in this article:
http://www.brainjar.com/css/positioning/default4.asp
Here's a sample that shows how this works.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <title>
      Overview Map
    </title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.1/js/dojo/dijit/themes/claro/claro.css">
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.1">
    </script>
    <script type="text/javascript">
      dojo.require("esri.map");
      dojo.require("esri.dijit.OverviewMap");
      var map;
      function init() {
        map = new esri.Map("mapDiv");
        var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
        map.addLayer(basemap);
        dojo.connect(map, 'onLoad', function(theMap) {
          //add the overview map
          var overviewMapDijit = new esri.dijit.OverviewMap({
            map: map,
            visible:true
          overviewMapDijit.startup();
      dojo.addOnLoad(init);
    </script>
  </head>
      <div style="height:100px;">
      "Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum."
      </div>
      <div id="mapDiv" style="border-style:solid; border-width:4px; border-color:green;width:400;height:500;position:relative;">
      </div>
  </body>
</html>
In this case if you use a Div with dojoType dijit.layout.BorderContainer and inside a map's Div Relative Position doesn't work.
JamesB
Setting position:relative worked for me, thank you
