Override widget texts
1565
04-26-2023 09:52 AM
BhavinSanghani
Is there any way to override widget strings in 4.x?
There used to be a way to override in 3.x https://developers.arcgis.com/javascript/3/jshelp/inside_bundle.html.
However, I don't find equivalent way in 4.x. I understand I can modify the locale to display the translated text but I can't really override it. e.g. Search widget icon displays tooltip "Search" and if I want to override it to "Search Address". Is it possible to override default widget texts?
Justin_Greco
I'm not aware of a way to do override it using a method similar to the 3.x API, but the tooltip on the search button is controlled by the title attribute, so you could do a querySelector for the .esri-search__submit-button class and change the title attribute.
<button aria-label="Search" class="esri-search__submit-button esri-widget--button" title="Search" type="button">
        searchWidget.when(() => {
          setTimeout(() => {
            searchWidget.container.querySelector('.esri-search__submit-button')?.setAttribute('title', 'Search address');
          }, 500);
BhavinSanghani
@Justin_Greco Thanks for replying about it. I thought of overriding by using dom query. I preferred overriding 3.x way so no need to worry about change in the selector class name as well as avoiding extra call. I am not sure why ESRI team has not supported overriding of the texts with 4.x.
