Override maps maxScale
3755
11-19-2015 07:19 AM
KarenRobine
The map gets its scales and LOD's from the first basemap added. But I need to override the map's maxScale. The basemap I'm using is set to 9027 for Max Scale, but I need the map's maxScale set to like 70.. Possible?  I know I could load the layer that has the lower maxScale first, and then load the other basemap, but I would like to not take the hit on performance.
RobertScheitlin__GISP
Karen,
   you can define additional LODs to your map in the maps constructor.
Specify LODs (levels of detail) | ArcGIS API for JavaScript
Karen,
