Out application uses KML. Is there an equivalent Esri javascript api that is compatible with the Cesium flyTo call??
2125
02-25-2016 07:50 AM
CarloMiceli
Our application uses KML. Is there an equivalent Esri javascript api that is compatible with the Cesium flyTo call??
Example
// viewer.dataSources.add(Cesium.KmlDataSource.load(kmldata))
// .then( function (dataSource) {
//   viewer.flyTo(dataSource.entities);
JeffJacobson
I'm not familiar with Cesium. Is your code sample just zooming to a feature?The esri/Map has various functions such as centerAt, centerAndZoom, and setExtent that can do this.
