Hello, it's me again, some days ago, you helped me alot, and thank you for it
I've got problem with optimization, my script works really slow, because my for loop add graphic from 20k to 50k times, is there any way to optimize it?
There is code: [HTML] <!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="te - Pastebin.com
Jędrek,
Can you share the json file for performance testing?
Robert,
Here is the json file for performance testing: Json file ,
Thanks a lot for your interest
Here is your code optimized to use web workers (it draws in about 2 seconds):
index.html:
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta http<SPAN class="operator token">-</SPAN>equiv<SPAN class="operator token">=</SPAN><SPAN class="string token">"Content-Type"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"text/html; charset=utf-8"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1, maximum-scale=1, user-scalable=no"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>Create circles<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fjs.arcgis.com%2F3.20%2Fesri%2Fcss%2Fesri.css" target="_blank">http://js.arcgis.com/3.20/esri/css/esri.css</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN> html<SPAN class="punctuation token">,</SPAN> body<SPAN class="punctuation token">,</SPAN> #map <SPAN class="punctuation token">{</SPAN> height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> #controls <SPAN class="punctuation token">{</SPAN> background<SPAN class="punctuation token">:</SPAN> #fff<SPAN class="punctuation token">;</SPAN> box<SPAN class="operator token">-</SPAN>shadow<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN> 6px 6px <SPAN class="operator token">-</SPAN>6px #<SPAN class="number token">999</SPAN><SPAN class="punctuation token">;</SPAN> color<SPAN class="punctuation token">:</SPAN> #<SPAN class="number token">444</SPAN><SPAN class="punctuation token">;</SPAN> font<SPAN class="operator token">-</SPAN>family<SPAN class="punctuation token">:</SPAN> sans<SPAN class="operator token">-</SPAN>serif<SPAN class="punctuation token">;</SPAN> height<SPAN class="punctuation token">:</SPAN> auto<SPAN class="punctuation token">;</SPAN> left<SPAN class="punctuation token">:</SPAN> 1em<SPAN class="punctuation token">;</SPAN> padding<SPAN class="punctuation token">:</SPAN> 1em<SPAN class="punctuation token">;</SPAN> position<SPAN class="punctuation token">:</SPAN> absolute<SPAN class="punctuation token">;</SPAN> top<SPAN class="punctuation token">:</SPAN> 1em<SPAN class="punctuation token">;</SPAN> width<SPAN class="punctuation token">:</SPAN> auto<SPAN class="punctuation token">;</SPAN> z<SPAN class="operator token">-</SPAN>index<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">40</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> #controls div <SPAN class="punctuation token">{</SPAN> padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN> <SPAN class="number token">0</SPAN> 1em <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fjs.arcgis.com%2F3.20" target="_blank">http://js.arcgis.com/3.20</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="keyword token">var</SPAN> map<SPAN class="punctuation token">,</SPAN> actual_JSON<SPAN class="punctuation token">,</SPAN> w<SPAN class="punctuation token">,</SPAN> gLayer<SPAN class="punctuation token">;</SPAN> <SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN> <SPAN class="string token">"esri/map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/SimpleFillSymbol"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/SpatialReference"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/graphic"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/GraphicsLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/Color"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/Extent"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/graphicsUtils"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/domReady!"</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN> Map<SPAN class="punctuation token">,</SPAN> SimpleFillSymbol<SPAN class="punctuation token">,</SPAN> SpatialReference<SPAN class="punctuation token">,</SPAN> Graphic<SPAN class="punctuation token">,</SPAN> GraphicsLayer<SPAN class="punctuation token">,</SPAN> Color<SPAN class="punctuation token">,</SPAN> Extent<SPAN class="punctuation token">,</SPAN> graphicsUtils <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"gray"</SPAN><SPAN class="punctuation token">,</SPAN> center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">22.741</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">51.39</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> slider<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN> zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">2</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> gLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GraphicsLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> opacity<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.7</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>gLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"load"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">typeof</SPAN><SPAN class="punctuation token">(</SPAN>w<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">==</SPAN> <SPAN class="string token">"undefined"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> w <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Worker</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"ProcessGraphics.js"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> w<SPAN class="punctuation token">.</SPAN>onmessage <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> wr <SPAN class="operator token">=</SPAN> event<SPAN class="punctuation token">.</SPAN>data<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN> <SPAN class="keyword token">var</SPAN> i <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i <SPAN class="operator token"><</SPAN> wr<SPAN class="punctuation token">.</SPAN>ilosc<SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN> <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> r <SPAN class="operator token">=</SPAN> Math<SPAN class="punctuation token">.</SPAN><SPAN class="token function">round</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">255</SPAN> <SPAN class="operator token">*</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>wr<SPAN class="punctuation token">.</SPAN>t<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">-</SPAN> wr<SPAN class="punctuation token">.</SPAN>minimalna<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">/</SPAN> wr<SPAN class="punctuation token">.</SPAN>licznik<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> b <SPAN class="operator token">=</SPAN> <SPAN class="number token">255</SPAN> <SPAN class="operator token">-</SPAN> r<SPAN class="punctuation token">;</SPAN> g <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Extent</SPAN><SPAN class="punctuation token">(</SPAN>wr<SPAN class="punctuation token">.</SPAN>x<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> wr<SPAN class="punctuation token">.</SPAN>y<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> wr<SPAN class="punctuation token">.</SPAN>x<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="number token">0.1</SPAN><SPAN class="punctuation token">,</SPAN> wr<SPAN class="punctuation token">.</SPAN>y<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="number token">0.1</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SpatialReference</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4326</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleFillSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleFillSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>r<SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>b<SPAN class="punctuation token">,</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> gLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>g<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setExtent</SPAN><SPAN class="punctuation token">(</SPAN>graphicsUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">graphicsExtent</SPAN><SPAN class="punctuation token">(</SPAN>gLayer<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">expand</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">1.2</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
ProcessGraphics.js:
<SPAN class="keyword token">var</SPAN> actual_JSON<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="token function">loadJSON</SPAN><SPAN class="punctuation token">(</SPAN> file<SPAN class="punctuation token">,</SPAN> callback <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> xobj <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">XMLHttpRequest</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> xobj<SPAN class="punctuation token">.</SPAN><SPAN class="token function">overrideMimeType</SPAN><SPAN class="punctuation token">(</SPAN> <SPAN class="string token">"application/json"</SPAN> <SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> xobj<SPAN class="punctuation token">.</SPAN><SPAN class="token function">open</SPAN><SPAN class="punctuation token">(</SPAN> <SPAN class="string token">'GET'</SPAN><SPAN class="punctuation token">,</SPAN> file<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">true</SPAN> <SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Replace 'my_data' with the path to your file</SPAN> xobj<SPAN class="punctuation token">.</SPAN>onreadystatechange <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN> xobj<SPAN class="punctuation token">.</SPAN>readyState <SPAN class="operator token">==</SPAN> <SPAN class="number token">4</SPAN> <SPAN class="operator token">&&</SPAN> xobj<SPAN class="punctuation token">.</SPAN>status <SPAN class="operator token">==</SPAN> <SPAN class="string token">"200"</SPAN> <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// Required use of an anonymous callback as .open will NOT return a value but simply returns undefined in asynchronous mode</SPAN> <SPAN class="token function">callback</SPAN><SPAN class="punctuation token">(</SPAN> xobj<SPAN class="punctuation token">.</SPAN>responseText <SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> xobj<SPAN class="punctuation token">.</SPAN><SPAN class="token function">send</SPAN><SPAN class="punctuation token">(</SPAN> <SPAN class="keyword token">null</SPAN> <SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="token function">load</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="token function">loadJSON</SPAN><SPAN class="punctuation token">(</SPAN> <SPAN class="string token">"l67kq-test.json"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN> response <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> actual_JSON <SPAN class="operator token">=</SPAN> JSON<SPAN class="punctuation token">.</SPAN><SPAN class="token function">parse</SPAN><SPAN class="punctuation token">(</SPAN> response <SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> x <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> t <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> y <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> dzielnik <SPAN class="operator token">=</SPAN> <SPAN class="number token">4</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//zmienna zmniejszajaca ilosc punktow na mapie</SPAN> <SPAN class="keyword token">var</SPAN> ilosc <SPAN class="operator token">=</SPAN> actual_JSON<SPAN class="punctuation token">.</SPAN>x <SPAN class="operator token">*</SPAN> actual_JSON<SPAN class="punctuation token">.</SPAN>y <SPAN class="operator token">/</SPAN> dzielnik<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN> <SPAN class="keyword token">var</SPAN> i <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i <SPAN class="operator token"><</SPAN> ilosc<SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN> <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">//20000->50000</SPAN> y<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN> actual_JSON<SPAN class="punctuation token">.</SPAN>XLONG<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> x<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN> actual_JSON<SPAN class="punctuation token">.</SPAN>XLAT<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> t<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN> actual_JSON<SPAN class="punctuation token">.</SPAN>T2<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">var</SPAN> maksymalna <SPAN class="operator token">=</SPAN> Math<SPAN class="punctuation token">.</SPAN>max<SPAN class="punctuation token">.</SPAN><SPAN class="token function">apply</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN> t<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> minimalna <SPAN class="operator token">=</SPAN> Math<SPAN class="punctuation token">.</SPAN>min<SPAN class="punctuation token">.</SPAN><SPAN class="token function">apply</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN> t<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> retObj <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN> minimalna<SPAN class="punctuation token">:</SPAN> minimalna<SPAN class="punctuation token">,</SPAN> licznik<SPAN class="punctuation token">:</SPAN> maksymalna <SPAN class="operator token">-</SPAN> minimalna<SPAN class="punctuation token">,</SPAN> x<SPAN class="punctuation token">:</SPAN> x<SPAN class="punctuation token">,</SPAN> y<SPAN class="punctuation token">:</SPAN> y<SPAN class="punctuation token">,</SPAN> t<SPAN class="punctuation token">:</SPAN> t<SPAN class="punctuation token">,</SPAN> ilosc<SPAN class="punctuation token">:</SPAN> ilosc <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">postMessage</SPAN><SPAN class="punctuation token">(</SPAN>retObj<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="token function">load</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Have you tried the code I provided using web workers?
