operations dashboard: target shortcut error
9045
10
07-17-2015 08:09 AM
TaN
Hello!
I am trying to set up the operations dashboard shortcut (Set up a development environment | Guide | ArcGIS API for JavaScript ), but when I try to change the 'Target' (using /extdbg: path name to my widgets folder), I keep coming up with this error:
The name 'C:\Users\ta.nguyen\AppData\Local\Apps\2.0\PLDDNPK0.71C\L3JNERPN.MW\p...\widgets"'
specified in the Target box is not valid. Make sure the path and file name are correct
Do you have any tips for changing the Target of the Operations Dashboard shortcut?
RobertScheitlin__GISP
TA,
   There has to be a space between .exe and /extdbg:
OperationsDashboard.exe /extdbg:C:\Extensions
TA,
   What is the path of the folder you are trying to set it to (I can not make it out in the image)? When I follow the instructions and use the simple path example of "C:\Extensions" I had no problem.
TaN
Hi Robert!
I'm trying to set the path of the folder to the same folder that contains all the widgets provided when I downloaded arcgis-web-appbuilder 1.1 (since this folder will contain my custom widget eventually).
C:\Users\ta.nguyen\Desktop\arcgis-web-appbuilder-1.1\client\stemapp\widgets
I tried the C:\Extensions and I still got the same error. I'll try again. Any other ideas?
Thanks Robert
TaN
I created an Extensions folder on my C: drive and I modified the 'Target' as
C:\Users\ta.nguyen\AppData\Local\Apps\2.0\PLDDNPK0.71C\L3JNERPN.MWC\oper...app_f464941b06bea132_000a.0003_790a069f1fec1fdc\OperationsDashboard.exe/extdbg:C:\Extensions
I still got the same error message. Hmm
TA,
TaN
Thank you Robert! It worked ^_^
JayChen
Hi TA,
Ops dashboard won't be able to recognize the widgets built for web app builder. For each of the extensions created for ops dashboard, there should be an associated .json file. This file contains manifest of the extension and this is what the ops dashboard app will be looking for.
Can you double-check?
-Jay
TaN
Hi Jay!
I haven't actually created an extension, so I haven't created a json file or a manifest file. I'm still new to developing using ArcGIS and programming in general. I'm trying to create a widget for the Web App Builder, so if you have any tips on how to get started on making a  WAB widget with limited JS experience, I would really appreciate your thoughts. Thank you for your input on this question, though! I didn't know that ops dashboard can't recognize widgets made for WAB, so you saved me from going down a rabbit hole..
Thanks again!
TA
JayChen
You are welcome TA. I am working with Operations Dashboard team so not really an expert on web app builder. But I have forwarded your question to WAB team so hopefully somebody will respond to your question soon.
Have a good one!
TaN
Hi Jay,
Thank you for forwarding my question! I appreciate your help (:
Happy Friday!
TA
