Open Street Map Solve Service Area
2019
03-12-2017 04:26 AM
AlbertoCañivano
Hi everybody!
Somebody has used the OSM network for making a Solve Service Area with API JavaScript for ArcGis?
I´ve got to make a widget in ArcGis Online but Solve Route and It works and I wonder If I can to do it for Service Area and JavaScript.
I would like to replicate this kind of example.
Basic service area | ArcGIS API for JavaScript 3.20
I ´ve changed the NaService reference for my NA Service OSM and nothing happens not even an error in my browser inspector
Thanks you!
RobertScheitlin__GISP
Alberto,
  OSM does not offer a Network Analyst rest end point like the example you are referencing. So
No this is not possible.
AlbertoCañivano
Hi Robert.
You can get a OSM Network dataset with this: (with their lilitations, obviously)
https://www.arcgis.com/home/item.html?id=c18d3d0d5c62465db60f89225fdd2698
I tested in my desktop and it worked in both Route solutor and Service Area solutor.
I published in my server a Route solutor and a server solutor Naservice.
After that, I did a Route widget (with my Na Service) in ArcGis Online and it worked as well.
With this Basic service area | ArcGIS API for JavaScript 3.20 example, it doesn´t work.
Thank you!
Alberto,
   OK, You would probably be better off asking a question directly to the custom code developer as this is not an esri developed capability.
