open popuptemplate when map load like the "who is gis app"
1373
08-15-2013 07:04 AM
joelde_freitas
hi, i am using the cluster sample to make a webapplication  like "who is GIS" app. i want to open the popuptemplate when the map is loaded.
How can i do this on the cluster sample. i cannot figure out.
thanks guys
joelde_freitas
hi. i solved the popup-template to open onload. and open the the popup windows randomly automatically.
i have copy the function onclick and create a loop that iterate through the clusterdata in the new function i created.
in the index page, i call that new function  in the addClusters(). when the index page open, the map.on("load",function()) call the addClusters().
thanks
JasonZou
Do you want to popup the infoWindow for one feature when the map is loaded?
If so, as to the cluster sample, you can invoke a function, like queryMyFeature, near the end of function addClusters. queryMyFeature will query a feature or features that you like to display the infoWindow. Then inside the callback function of the query, you can use
var popLocation = response.features[0].geometry;
map.infoWindow.setFeatures(response.features);
map.infoWindow.show(popLocation);
joelde_freitas
i will try.
joelde_freitas
thanks
