Open Info Window on grid RowClick
2738
09-25-2014 08:12 AM
RichardMoussopo
I have the code below that shows the info window on map click. I would like to call the same function in the gridRowClick event.
function identifyPOI(evt) {
    var measureMode = dojo.query(".esriButton .dijitButtonNode").some(function (node, index, arr) {
        if (node.childNodes[0].checked) {
            //at least one of the measure tools is active so disable identify
            return true;
    if (!measureMode) {
        var identify = new esri.tasks.IdentifyTask(".../MapServer");
        var identifyParams = new esri.tasks.IdentifyParameters();
        identifyParams.geometry = evt.mapPoint;
        identifyParams.mapExtent = map.extent;
        identifyParams.returnGeometry = true;
        identifyParams.tolerance = 3;
        map.infoWindow.clearFeatures();
        //Define a good infoTemplate
        var infoTemplateUtilities = new esri.InfoTemplate();
        infoTemplateUtilities.setTitle("FacilityID: <br/> <b>${Facility Identifier}</b>");
        infoTemplateUtilities.setContent("Open file:  <b> <a href='Documentation/${MAPREF}.pdf' target='_blank'> ${MAPREF} </a>  </b><br/>" +
                                  "Install Date: <b>${Install Date} </b><br/>" +
                                  "Material: <b>${Material}</b><br/>" +
                                  "Diameter: <b>${Diameter}</b> <br/>" +
                                  "Status: <b>${Status}</b> <br/>" +
                                  "Last Update Date: <b>${Last Update Date}</b> <br/>" +
                                  "Water Type: <b>${Water Type}</b> <br/>" +
                                  "Lenght(ft): <b>${SHAPE_Length}</b> <br/>");
        try {
            identify.execute(identifyParams, function (results) {
                map.infoWindow.setFeatures(dojo.map(results, function (result) {
                    var feature = result.feature;
                    feature.setInfoTemplate(infoTemplateUtilities);
                    return feature;
                map.infoWindow.show(evt.mapPoint);
        catch (ex) {
            alert(ex.toString());
function onRowClickHandler(evt) {
    var clickedUtilityId = grid.getItem(evt.rowIndex).OBJECTID;
    var selectedUtility;
    dojo.forEach(map.graphics.graphics, function (graphic) {
        if ((graphic.attributes) && graphic.attributes.OBJECTID === clickedUtilityId) {
            selectedUtility = graphic.geometry;
            return;
    var thePoly = selectedUtility;
    var theExtent = thePoly.getExtent();
    map.setExtent(theExtent, true);
    //and display the infoWindow
    var utilityLenght = thePoly.paths[0].length;
    if(utilityLenght % 2 !=0){
       utilityLenght = utilityLenght - 1;
       var pointXY = thePoly.paths[0][(utilityLenght / 2)];
       var infoPoint = new esri.geometry.Point(pointXY[0], pointXY[1], new esri.spatialReference({ wkid: 102723 }));
       try{
           identifyPOI(evt.infoPoint); //<====  here is where I am not sure...
       catch (ex) {
the image below is the final result I am trying to achieve.
KenBuja
MVP Esteemed Contributor
I think the simplest thing to do would be to rewrite your identifyPOI function so it takes a point instead of an event, since you don't use any other part of the event.
function identifyPOI(point) {
You'll just have to make sure you pass in the point on the map click. If that isn't possible, you could do something like this
    openInfoWindow(evt.mapPoint);
function openInfoWindow(point) {
            return true;
    if (!measureMode) {
        try {
                    return feature;
                map.infoWindow.show(point);
        catch (ex) {
and inf the onRowClickHandler function, use
  1.        try{
  2.
  3.       openInfoWindow(infoPoint); //<====  here is where I am not sure...
  4.         }
  5.        catch (ex) {
  6.            alert(ex.toString());
  7.        }
RichardMoussopo
Thank you Ken for replying...
I tried what you said and it did not work. I also tried to change
identifyParams.geometry = point;   line 16 above
but still nothing.
TracySchloss
Honored Contributor
Did you get this figured out yet?  It seems like a post that even a week old gets lost down the list.
