Open Geodatabase
3543
02-24-2016 09:57 AM
PeterBennett
Hello All,
In ArcGIS SDK for NET I can open a Geodatabase file, created in ArcGis for Desktop (ArcMap).
Is it possible to load/open a Geodatabase using ArcGIS API for Javascript?
Please advice
Best Regards
RobertScheitlin__GISP
Peter,
    No a web client based API like JS has limited or no file system access. The JS API needs RESTfull access to layers and data through ArcGIS Server or some web service that provides similar access to the GDB.
Peter,
PeterBennett
Thank you Robert, I begin to understand...
Is it possible to share it to ArcGis Online and open from there?
Best Regards
PeterBennett
Best Regards
Peter,
   You can add a particular feature class from the GDB as a FeatureLayer service.
