OnRenderEnd event
1258
05-07-2013 01:54 PM
BrianBeck
I have not been able to find any events either on the Map or FeatureLayer objects that can be connected to for when a layer has finished rendering on the map.  I have code that sets the Renderer of a FeatureLayer dynamically based on user input.  When I call FeatureLayer.redraw() the layer shows the new symbology on the map, but my legend doesn't update until I call legend.refresh().
I have wrapped my Renderer code in its own custom widget, which is not aware of the legend.  What I would like to do is connect the legend.refresh() to either a map event or layer event.  The ideal event would be one that is fired when a layer (or the map) finishes drawing, but I haven't found an event in the API for onDrawEnd of the Map or FeatureLayer.
Is there an event that is fired when a layer or the map finishes drawing even if the extent hasn't changed?
NiranjanBorawake
Hello Brian,
I think you are looking for onUpdateEnd event of FeatureLayer.
Please have a look at this example and understand how "onUpdateEnd" event is used.
Niranjan
BrianBeck
Hello Brian,
Niranjan
Thanks Niranjan,
I looked into the "onUpdateEnd" event and unfortunately this isn't quite what I need.  The "onUpdateEnd" event only occurs when the FeatureLayer content is refreshed.  I am using the "redraw" method of the FeatureLayer to redraw the layer with the new symbology because I do not want to requery the server.  The "redraw" method does not update content in the FeatureLayer so the "onUpdateEnd" event is not triggered.
I guess what I really need is an "onDrawEnd" event.
