only one attribute returned for a selected feature graphic
4285
15
06-15-2018 01:07 PM
JayHill
My console log for a selected feature popup.watch is only showing one attribute when there should be all of them returned. Is it something simple I am overlooking?
var stuffLayer = new MapImageLayer({
          url: "https://",
          sublayers: [{
                title: "Stuff",
                visible: true,
                outFields: ["*"],
                popupTemplate: {
                  title: "Stuff",
                  content: createClickContentType
                //minScale: 100000
                title: "Stuff 2",
                visible: false,
                //minScale: 100000,
                //legendEnabled: false
              title: "Stuff 3",
              visible: false,
              outFields: ["*"],
              popupTemplate: {
                title: "Stuff 3",
              //maxScale: 100000
              title: "Metadata",
              visible: false,
              popupTemplate: {
                title: "Metadata",
                content: createClickContentPro
mapView.map.add(stuffLayer);
          mapView.popup.watch(["selectedFeature"], function(g){
             console.log(g);
Tags (1)
RobertScheitlin__GISP
Yes
JayHill
Is there special notation for the related table fields? Similar to the 3.x api ?
Jay,
   From what I understand you use something like this for the field name
relationships/0/Point_Count_COMMON
JayHill
Ok, I can get the values I need returned to the console but nothing in the popup. Is it a timing issue to return them back to the popupTemplate function?
            contentSpecies = function(value, key, data) {
                var contentSpecies = "";
                objectID = data.OBJECTID;
                var queryTask = new QueryTask({
                    url: "https://blah.com/MapServer/1"
                var relationQuery = new RelationshipQuery({
                    objectIds: [objectID],
                    outFields: ["Species", "Notes", "Status"],
                    returnGeometry: true,
                    relationshipId: 0
                queryTask.executeRelationshipQuery(relationQuery)
                .then(function(rslts) {
                    var features = rslts[objectID].features;
                    features.forEach(function(ftr) {
                        var t = ftr.attributes;
                        var species = t.Species;
                        contentSpecies += "<span class='bold' title='Species'><b>Species: </b></span>" + species + "<br/>";
                        var notes = t.Notes;
                        contentSpecies += "<span class='bold' title='Notese'><b>Notes: </b></span>" + notes + "<br/>";
                        var status = t.Status;
                        contentSpecies += "<span class='bold' title='Status'><b>Status: </b></span>" + status + "<br/>";
                    console.log(contentSpecies);
                    //return contentSpecies;
Jay,
   You are returning contentSpecies before the relationship query is done.
JayHill
I tried with the async await feature but it is not even firing the function now when called.
contentSpecies = async function(value, key, data) {
  console.log("functioning");
    try {
            url: "https://webmaps.com/MapServer/1"
            relationshipId: 0
        let rslts = await queryTask.executeRelationshipQuery(relationQuery);
        console.log(features);
    } catch (e) {
        console.error(e);
    } finally {
