onExtentChange on esri 4.X
2863
07-28-2017 08:26 AM
UdyWa
Does esri 4.x versions has an event equivalent to onExtentChange for Map?
map.on("extent-change", function(){//do things});
Tags (1)
JohnGrayson
Esri Alum
Read the section "Watching properties" here: Working with properties | ArcGIS API for JavaScript 4.4
view.watch("extent", (newValue, oldValue, property, object)=>{
  console.info("Extent has changed: ", newValue);
JohnGrayson
Esri Alum
UdyWa
Does this work in 4.3 or is this new feature in 4.4?
JohnGrayson
Esri Alum
Since 4.0; watching properties is the 4.x way of handling this use case.
UdyWa
This is only for setting new values to the existing values. What I need to is load some markers to exact points on extent change so the markers will be loaded only in the visible area.
JohnGrayson
Esri Alum
Please read the section "Watching properties".
