One Feature layer in Template Picker based on Combobox selection?
1380
11-25-2013 11:21 AM
ionarawilson1
I need to have just one single feature in the template picker of the editor widget based on the selection of a combobox. However, the template picker is being created after the add layer result event. Because the add layer result fires before the change event in the combobox, I had to create a deferred function but the function works well the first time and the second time it does not work, because the deferred function has already been resolved. Can  you please take a look at my code and tell me the best way to do this? Thank you so much for any help!
var stewardship = new esri.layers.FeatureLayer("http://tfsgis-iisd01:6080/arcgis/rest/services/FeatureServiceStewAAreaAPoint/FeatureServer/0",
          mode: FeatureLayer.MODE_SELECTION, id: 'stewardship',
          outFields: ['*']
  var activityarea = new esri.layers.FeatureLayer("http://tfsgis-iisd01:6080/arcgis/rest/services/FeatureServiceStewAAreaAPoint/FeatureServer/1",
          mode: FeatureLayer.MODE_SELECTION, id: 'activityarea',
          outFields: ['*']
          deferred = new dojo.Deferred();
         deferred.then(function(value){
        console.log(value);
        activityValue = dijit.byId('Activity').get('displayedValue')
     if (activityValue == "Forest Stewardship Plan")
  {   map.removeAllLayers;
   alert("TEST")
   map.addLayers([stewardship]);
    if (activityValue == "Non Forest Stewardship Plan")
   alert("TEST2")
   map.addLayers([activityarea]);
    map.on("layer-remove", layerremove)
 function layerremove()
  TemplatePicker.destroy()
//   map.addLayers([activityarea]);
        function initEditor(evt) {
           var templateLayers = arrayUtils.map(evt.layers, function(result){
   return result.layer;
 // TEST: Changed to stewardship instead of templateLayers
          var templatePicker = new TemplatePicker({
            featureLayers: templateLayers,
            grouping: true,
            rows: "auto",
            columns: 3
          }, "templateDiv");
          templatePicker.startup();
          var layers = arrayUtils.map(evt.layers, function(result)
   var fieldInfos= arrayUtils.map(result.layer.fields,function(field){
            if(field.name === 'RecipientLast'){
              return {'fieldName': field.name,'label':'Rec Last Name'}
    if(field.name === 'RecipientFirst'){
              return {'fieldName': field.name,'label':'Rec First Name'}
    //    return {'fieldName': field.name,'label':'Rec First Name',stringFieldOption:esri.dijit.AttributeInspector.STRING_FIELD_OPTION_TEXTAREA
   if(field.name === 'Phone'){
              return {'fieldName': field.name,'label':'Phone', 'customField':myDijit}
   if(field.name === 'ZipCode'){
              return {'fieldName': field.name,'label':'ZipCode', 'customField':myDijit2}
   if (field.name == 'DateStart')
       return {'fieldName': field.name,'label':'Start Date', 'customField': datedijit }
            else{
              return {'fieldName': field.name,'label':field.alias}
            return { featureLayer: result.layer, 'fieldInfos':fieldInfos};
        //add a default value for newly added features
          var settings = {
            map: map,
            templatePicker: templatePicker,
            layerInfos: layers,
            toolbarVisible: true,
            createOptions: {
              polylineDrawTools:[ Editor.CREATE_TOOL_FREEHAND_POLYLINE ],
              polygonDrawTools: [ Editor.CREATE_TOOL_FREEHAND_POLYGON,
                Editor.CREATE_TOOL_CIRCLE,
                Editor.CREATE_TOOL_TRIANGLE,
                Editor.CREATE_TOOL_RECTANGLE
            toolbarOptions: {
              reshapeVisible: true,
     mergeVisible: true,
     cutVisible: true
          var params = {settings: settings};
          var myEditor = new Editor(params,'editorDiv');
          //define snapping options
          var symbol = new SimpleMarkerSymbol(
            SimpleMarkerSymbol.STYLE_CROSS,
            15,
            new SimpleLineSymbol(
              SimpleLineSymbol.STYLE_SOLID,
              new Color([255, 0, 0, 0.5]),
              5
            null
          map.enableSnapping({
            snapPointSymbol: symbol,
            tolerance: 20,
            snapKey: keys.ALT
        }//end of init editor function
dojo.connect(dijit.byId("Activity"), 'onChange', function(value){
               deferred.resolve("success");
              return deferred.promise;
