Ocean Basemap Issue
1415
06-24-2011 07:14 AM
EricLake
Since the new Ocean Basemap was added, i have noticed that if it is the default basemap loaded, the zoom levels of the map are then restricted no matter what layer is chosen after that.
like in this sample.
http://help.arcgis.com/en/webapi/javascript/arcgis/demos/widget/widget_basemapsthumbnail.html
Is there are quick way around if using the thumbnail picker widget?
KellyHutchins
Esri Notable Contributor
One approach to workaround this issue is to add a basemap with more zoom levels before creating the basemap gallery. In this snippet the World Topo Map is added so the map will be initialized with more levels:
   var initBasemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
        map.addLayer(initBasemap);
        createBasemapGallery();
EricLake
Thanks Kelly!
