Obligation due to use of dojo component
1664
05-16-2013 07:11 PM
uu
What kind obligation my product will have if I use the dojo component in my product?
If I just using dojo to render the ArcGIS map then do I need to keep my product as open source?
My concern is about licensing of the dojo.
VinayBansal
As per my understanding Dojo has AFL and BSD license only. Dojo replaced its (L)GPL license with BSD license
And its documentaion says that
You may:
Freely use Dojo to build applications and services
Distribute Dojo as a part of commercial products
Modify Dojo, make extensions to the toolkit, and produce your own add-on components with no requirement that you give your code away or contribute it back to the project
Just to re-iterate, you can build commercial software with Dojo without obtaining a separate license or incurring any other obligations.
VinayBansal
uu
thanks for the information Vinay.
Does dojo have any GPL obligation?
VinayBansal
You may:
uu
thanks for the information 🙂
