Object has no method 'query'
1096
07-09-2012 10:42 AM
KeithSandell
I'm extending the "Add Shapefile" example to allow the user to select a column from the shapefile by which to set the symbology of the layer added...
Taking a featureCollection, extracting field names to populate a dijit.form.ComboBox:
This part works:
function populateColumnDropDown(featureCollection){
 names = featureCollection.layers[0].layerDefinition.fields;
 var fieldNames = [];
 for(i = 0; i < names.length; i++){
  if(names.name != "FID"){
   fieldNames.push({name:names.name});
 var dataItems = {
         identifier: 'name',
         label: 'name',
         items: fieldNames
 var store = new dojo.data.ItemFileReadStore({data:dataItems});
 dijit.byId("columnInput").store = store;
<select id="columnInput" dojotype="dijit.form.ComboBox" style="width:150px;" value="Select Column" title="Select Column To Symbolize" fetchProperties="{sort:[{attribute:'name', descending:false}]}" onChange="setSymbology();" disabled></select>
No errors are thrown until I click the comboBox to see the values. Then it throws a: Object has no method 'query' error.
Any thoughts?
JeffPace
This part works:
 var dataItems = {
         identifier: 'name',
         label: 'name',
         items: fieldNames
Any thoughts?
Clicking it fires the "setSymbology()" function, please post that code.
KeithSandell
"onChange" not "onClick" fires the setSymbology() function, as it has it that function has nothing in it.
The onChange event will not fire if the ComboBOx is not populated with the values from the datastore so that you can affect a change.
