Not entire list is being displayed in feature menu of popup
4918
11
02-28-2022 07:22 AM
AnantSharma
I was trying to get the list of points in feature menu of popup. But as shown in below snapshot, feature menu list is showing only 20 list . But there are 58 points there. So how can I display entire 58 points in the feature menu list.Bug in ESRI.PNG
KristianEkenes
Hi. What browser are you using? This appears to be a bug. When the popup contains more than 20 features, it only loads the first 20, then it (should) paginates queries for the remaining features as you scroll through the list. If you can consistently reproduce, I would report this to technical support so we can get a bug logged and fixed soon.
AnantSharma
yes it's consistently there. If I click on back page initiation and go to 58 item (last) then entire list with 58 items are appearing but after refresh of page same issue as above screenshot.
I am using google chrome browser and API version is 4.20
KristianEkenes
I'm not able to reproduce this on my side. Perhaps tech support will be able to help you diagnose it...
KristianEkenes
Also, which API version are you using?
AnantSharma
Browser -> chrome .... API version 4.20
AnantSharma
@KristianEkenes  if possible can you tell me how can I enable this browse feature widget in my popup, it will show the list. Also is there a way to keep the list view always open.browseFeature.PNG
KristianEkenes
There isn't a way to do this at the moment, but we can expose a property on the PopupViewModel that would allow you to always have browsing enabled.
KristianEkenes
FYI, I just logged an issue to expose this feature in a follow up release.
AnantSharma
@KristianEkenes ,Thanks, If that property can be enabled, it will be of great help. Also how can I bring this widget "Browsing feature" as you can see in the snapshot I don't have it.
