Not able to query related record
2028
09-02-2013 01:53 AM
DeepikaJain
Dear All
I want to query related record of a feature during identify using ArcGIS Javascript API 3.5
This is how I am working on it:
var relatedQuery = new esri.tasks.RelationshipQuery();
          relatedQuery.outFields = ["*"];
          relatedQuery.relationshipId = 1;
          relatedQuery.objectIds  = 2102;
        var layerinfo = baseLayer.layerInfos;
    //   map.layerIds
        var layer = layerinfo[4];
            layer.queryRelatedFeatures(relatedQuery, function(relatedRecords) {
            alert("related");
but it gives error that "the object doesnot support this property or method". I have multiple mapservices in my map.
Please help!
Thanks
Deepika
VinayBansal
Dear All
    //   map.layerIds
            alert("related");
Thanks
Deepika
related query obectIds property is an array....
relatedQuery.objectIds = [2102];
Also make sure that related table is added in the map service you are referring.....
DeepikaJain
Hi
Thanls for the help, I tired the workaround but still I get the same error. Is it that the task works only for feature service layers and not for map service layers. The related data is there in the same mxd which is published as a service and if I query through REST endpoint, I do get the results.
VinayBansal
Hi
Yes queryRelatedFeatures works for FeatureLayer.
                    relatedQuery.objectIds = [2012];
                    relatedQuery.returnGeometry = false;
                    var myFeatureLayer = new esri.layers.FeatureLayer(<<mapServiceURL>> + "/" + <<layerId>>, {
                        mode: esri.layers.FeatureLayer.MODE_SELECTION
myFeatureLayer .queryRelatedFeatures(relatedQuery, function (relatedRecords) {
//Code after records are found
JasonZou
// map.layerIds
layerInfo cannot be used to query related records. Two options:
  1. Use QueryTask.executeRelationshipQuery(parameters,callback?,errback?)
  2. Create a feature layer for layerinfo[4], and then queryRelatedFeatures(relQuery,callback?,errback?). Sample.
