Not able to hide zoomto button on popup
1734
05-12-2021 07:09 AM
GiovanniVanore1
Hello Guys,
I am using arcGIS 4.19 with ES module. Trying to hide default Zoomto button.
used code:
view.popup.dividedActions.inlineActions.items[0].className = "hideZoomTO"
view.popup.dividedActions.inlineActions.items[0].visible = false;
this.view.popup.viewModel.allActions.getItemAt(0).visible = false
These all code are working but taking sometime. That means Its hiding but taking some micro seconds to hide the button.
Is there any method to hide the default button.
ReneRubalcava
Esri Frequent Contributor
You can set the PopupTemplate overWriteActions to true and don't provide an actions array.
https://developers.arcgis.com/javascript/latest/api-reference/esri-PopupTemplate.html#overwriteActio...
This will remove it.
Paco
Here is another option that worked great for me-
view.popup.visibleElements = {
actionBar: false,
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Popup.html#VisibleElement...
