nevermind (can't get the geocode example to work with my services...)
821
10-20-2010 10:22 AM
ThomasMeyer
nevermind, it worked on the 5th different address I used, not sure why, just gonna keep grinding on
using 9.3. I have a map service and geocode service I'm trying to substitute with the ones used in esri's sample, but my map won't perform the geocode/pan/zoom when you click 'locate'.
I'm wondering if:
var geom = esri.geometry.geographicToWebMercator(candidate.location);
won't work right with the NAD_STATE_PLANE projection of my services
Bold- altered
Purple- taken out due to javascript error from candidate.attributes.Loc_name (which I then tried candidate.attributes.aug_09_co_cl_zip_mod_loc2, to no avail)
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7" />
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Find Address</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.1/js/dojo/dijit/themes/claro/claro.css">
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.1"></script>
    <script type="text/javascript">
      dojo.require("esri.map");
      dojo.require("esri.tasks.locator");
      var map, locator;
      function init() {
        var initExtent = new esri.geometry.Extent({"xmin":650000,"ymin":630000,"xmax":700000,"ymax":660000,"spatialReference":{"wkid":102651}});
        map = new esri.Map("map", { extent: initExtent});
        var tiledMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://fpscnsde:8399/arcgis/rest/services/transportation2/MapServer");
        map.addLayer(tiledMapServiceLayer);
        locator = new esri.tasks.Locator("http://fpscnsde:8399/arcgis/rest/services/tran_geocode2/GeocodeServer");
        dojo.connect(locator, "onAddressToLocationsComplete", showResults);
      function locate() {
        map.graphics.clear();
        var add = dojo.byId("address").value.split(",");
        var address = {
          Street : add[0],
          Zone: add[1]
        locator.addressToLocations(address,["aug_09_co_cl_zip_mod_loc2"]);
      function showResults(candidates) {
        var candidate;
        var symbol = new esri.symbol.SimpleMarkerSymbol();
        var infoTemplate = new esri.InfoTemplate("Location", "Address: ${address}<br />Score: ${score}<br />Source locator: ${locatorName}");
        symbol.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_DIAMOND);
        symbol.setColor(new dojo.Color([255,0,0,0.75]));
        var points =  new esri.geometry.Multipoint(map.spatialReference);
        for (var i=0, il=candidates.length; i<il; i++) {
          candidate = candidates;
          if (candidate.score > 70) {
            var attributes = { address: candidate.address, score:candidate.score, locatorName:candidate.attributes.Loc_name };
            var graphic = new esri.Graphic(geom, symbol, attributes, infoTemplate);
            map.graphics.add(graphic);
            map.graphics.add(new esri.Graphic(geom, new esri.symbol.TextSymbol(attributes.address).setOffset(0, 8)));
            points.addPoint(geom);
        map.setExtent(points.getExtent().expand(3));
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
    Address : <input type="text" id="address" size="60" value="519 W Dickson, 72701" /> <i>(Address, City, State, Zip)</i>
    <input type="button" value="Locate" onclick="locate()" /><br />
    <br />
    <div id="map" style="width:1200px; height:600px; border:1px solid #000;"></div>
  </body>
</html>
when I click 'locate', it moves the map slightly (and incorrectly) and I then loose the ability to pan
this is my second day of trying to figure this out, thanks to anyone!
