Network Analyst Service with Feature Service Layer
1395
03-13-2014 01:24 PM
BenHammer1
I am working on a trails map using the Network Analyst extension. It is running, but I would like to know if is possible to add a feature layer underneath it. Currently, there are no trails underneath the network layer.
code here:
http://www.public.asu.edu/~bhammer/dm/
thanks!
JeffPace
Feature Layers are graphics, as are the results of the NA service.  So they will be drawn in the order added.
If you want to change the order, you would have to create Multiple GraphicsLayers, which you could then control the order of.
JeffPace
As a side not, if you don't need the feature layer functionality, don;t use it.
If you add the Trails as a Dynamic/Tiled map it will draw underneath
BenHammer1
Thanks Jeff!
I added the trails as a dynamic service layer with annotation labels. It's getting closer.
