Needing help querying Map Service for PoPUP
6842
10
09-01-2014 09:09 PM
CharlesGant
I have the following service loaded into my map:
http://gis.fema.gov/REST/services/FEMA/LSR/MapServer
I would like to be able to sample the graphics from this service in a popup as if it is loaded into an AGOL Webmap.  Unless I'm confused, the above link is to a Map Service and not Feature Layer.  However, when I inspect the layers, they area labeled as Feature Layers.  I read somewhere that you cannot query a Map Service for features.  So I'm confused.  Can I query this layer to be able to display ALL attributes in a popup?  If so, how?
Thanks in advance
EhabEl-Masry
Hi Charles
u can try this esri sample, with few editing, u should be able to query any layer in your map service..
here u are:
Feature layer hover | ArcGIS API for JavaScript
From your service directory, your layers supports the "Query" REST function.
CharlesGant
I appreciate the response. I tried incorporating the code and the console prints out:
TooltipDialog in not a constructor
I have all the following in the require and function calls, exactly as it is in the example.  I do have many other requires, however I'm fairly certain that I have the order consistent because the page loads fine.  Typically if the order is out, the page bombs on load.
      require([
"esri/map", "esri/layers/FeatureLayer",
"esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol",
"esri/renderers/SimpleRenderer", "esri/graphic", "esri/lang",
"esri/Color", "dojo/number", "dojo/dom-style",
"dijit/TooltipDialog", "dijit/popup", "dojo/domReady!"
], function(
Map, FeatureLayer,
SimpleFillSymbol, SimpleLineSymbol,
SimpleRenderer, Graphic, esriLang,
Color, number, domStyle,
TooltipDialog, dijitPopup
EhabEl-Masry
It is hard to guess what else you are trying to load in the "require" section, but according to your description, it seems that it is a packaging issue. Make sure that the paths you add - like "someFolder/someJavascriptModule"- is mapped to a physical resource in your web application.
Feel free to share the code..
CharlesGant
require(["esri/map","esri/geometry/webMercatorUtils","esri/dijit/BasemapToggle","dojo/_base/connect","dijit/form/Button",
  "dojo/dom","dojo/parser","dojo/ready","dojo/on", "dojo/_base/Color","dojo/keys", "dojo/_base/array","dojo/number","dijit/registry",
  "esri/config","esri/SnappingManager","esri/dijit/Measurement","esri/tasks/locator","esri/graphic","esri/layers/GraphicsLayer","esri/dijit/Popup",
  "esri/dijit/PopupTemplate","esri/layers/WMSLayer","esri/layers/WMSLayerInfo","esri/urlUtils","esri/arcgis/utils","esri/geometry/Extent",
  "esri/layers/FeatureLayer","esri/layers/ImageParameters","esri/layers/CSVLayer","esri/layers/ArcGISTiledMapServiceLayer","esri/layers/ArcGISDynamicMapServiceLayer",
  "esri/symbols/SimpleLineSymbol","esri/symbols/SimpleFillSymbol","esri/symbols/TextSymbol","esri/symbols/Font","esri/tasks/GeometryService",
  "esri/tasks/query","dojo/dom-construct","dojo/dom-style","esri/renderers/SimpleRenderer","esri/layers/LabelLayer","esri/renderers/ClassBreaksRenderer",
  "esri/InfoTemplate","esri/symbols/SimpleMarkerSymbol","esri/symbols/PictureMarkerSymbol","agsjs/dijit/TOC","dijit/layout/BorderContainer","dijit/layout/ContentPane",
  "dijit/TitlePane","esri/dijit/Scalebar","esri/TimeExtent","esri/dijit/TimeSlider","esri/layers/TimeInfo","esri/request","dojo/_base/lang",
  "dojo/date/locale","dojo/request/xhr","dojo/fx","dojo/_base/array","dijit/TooltipDialog","dijit/popup","dojo/domReady!"], function(Map, webMercatorUtils, BasemapToggle, connect, Button, dom, parser, ready, on, Color, keys, arrayUtils, number, registry, esriConfig, SnappingManager, Measurement,
  Locator, Graphic, GraphicsLayer, Popup, PopupTemplate, WMSLayer, WMSLayerInfo, urlUtils, arcgisUtils, Extent, FeatureLayer, ImageParameters, CSVLayer, ArcGISTiledMapServiceLayer, ArcGISDynamicMapServiceLayer,
  SimpleLineSymbol, SimpleFillSymbol, TextSymbol, Font, GeometryService, Query, domConstruct, domStyle, SimpleRenderer, LabelLayer, ClassBreaksRenderer, InfoTemplate,
  SimpleMarkerSymbol, PictureMarkerSymbol, TOC, BorderContainer, ContentPane, TitlePane, Scalebar, TimeExtent, TimeSlider, TimeInfo, esriRequest, lang, locale, xhr, array, TooltipDialog, dijitPopup)
CharlesGant
Could not post complete page code as it is 1500 lines.
KenBuja
MVP Esteemed Contributor
I'm not sure this is the issue, but you've added "dojo/_base/array" twice, once after Keys and once before TooltipDialog.
When I add many modules, I find it more helpful to organize them logically
require(["dojo/_base/array",
         "dojo/_base/declare",
         "dojo/_base/lang",
         "dojo/Deferred",
         "dojo/json",
         "dojo/ready",
         "dojox/gfx/fx",
         "dgrid/OnDemandGrid",
         "dgrid/Selection",
         "dgrid/selector",
         "dgrid/extensions/ColumnResizer",
         "dgrid/extensions/ColumnHider",
         "dgrid/util/mouse",
         "dgrid/extensions/DijitRegistry",
         "dijit/MenuItem",
         "dijit/layout/TabContainer",
         "dijit/registry",
         "esri/map",
         "esri/dijit/Basemap",
         "esri/dijit/BasemapGallery",
         "esri/dijit/BasemapLayer",
         "modules/DVParameters",
         "agsjs/dijit/TOC",
         "dojo/fx",
         "dojo/domReady!"
], function (array, declare, lang, Deferred, JSON, ready,
             fx,
             Grid, Selection, selector, ColumnResizer, ColumnHider, mouseUtil, DijitRegistry,
             MenuItem, TabContainer, registry,
             Map, InfoTemplate,
             Basemap, BasemapGallery, BasemapLayer, Scalebar,
             DVParameters
CharlesGant
Really appreciate the reply, I removed the extra "dojo/_base/array" and still getting the error printed in console. Also removed the corresponding "array" function call.
KenBuja
Can you show the portion of your code where you use TooltipDialog?
CharlesGant
All I have added in is below.  Fairly simple addition at this point.  I stopped incorporating the example after it failed here.
        dialog = new TooltipDialog({
          id
: "tooltipDialog",
          style
: "position: absolute; width: 250px; font: normal normal normal 10pt Helvetica;z-index:100"
        dialog
.startup();
