Need to create a custom widget with multiple widgets enclosed within.
1395
11-03-2023 01:30 PM
tippu_ks
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
<title>ArcGIS Maps SDK for JavaScript Tutorials: Display a scene</title>
<style>
html, body, #viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.28/esri/themes/light/main.css">
<script src="https://js.arcgis.com/4.28/"></script>
<script>
require([
"esri/config",
"esri/Map",
"esri/views/SceneView",
"esri/layers/FeatureLayer",
"esri/widgets/Expand",
"esri/widgets/BasemapGallery",
"esri/widgets/AreaMeasurement3D",
"esri/widgets/LineOfSight",
"esri/widgets/LayerList",
"esri/widgets/Legend",
"esri/widgets/Compass"
], function(esriConfig, Map, SceneView, FeatureLayer, Expand, BasemapGallery, AreaMeasurement3D, LineOfSight, LayerList, Legend, Compass) {
esriConfig.apiKey = "AAPKb6723de7d64b410ca4b3106297567589haGVc4dtuVBzVw1isFbYLznf9QbiJJ27VVkAZruKb0Y3N91W2kBNUn268t7DvYPC";
const map = new Map({
basemap: "arcgis/topographic", // basemap styles service
ground: "world-elevation", //Elevation service
const view = new SceneView({
container: "viewDiv",
map: map,
camera: {
position: {
x: -118.808, //Longitude
y: 33.961, //Latitude
z: 2000 //Meters
tilt: 75
// Define a pop-up for Trailheads
const popupTrailheads = {
"title": "Trailhead",
"content": "<b>Trail:</b> {TRL_NAME}<br><b>City:</b> {CITY_JUR}<br><b>Cross Street:</b> {X_STREET}<br><b>Parking:</b> {PARKING}<br><b>Elevation:</b> {ELEV_FT} ft"
const trailheads = new FeatureLayer({
url: "https://services3.arcgis.com/GVgbJbqm8hXASVYi/arcgis/rest/services/Trailheads_Styled/FeatureServer/0",
outFields: ["TRL_NAME","CITY_JUR","X_STREET","PARKING","ELEV_FT"],
popupTemplate: popupTrailheads
map.add(trailheads);
// Define a popup for Trails
const popupTrails = {
title: "Trail Information",
content: [{
type: "media",
mediaInfos: [{
type: "column-chart",
caption: "",
value: {
fields: [ "ELEV_MIN","ELEV_MAX" ],
normalizeField: null,
tooltipField: "Min and max elevation values"
const trails = new FeatureLayer({
url: "https://services3.arcgis.com/GVgbJbqm8hXASVYi/arcgis/rest/services/Trails_Styled/FeatureServer/0",
outFields: ["TRL_NAME","ELEV_GAIN"],
popupTemplate: popupTrails
map.add(trails,0);
// Create a BasemapGallery widget instance and set
// its container to a div element
const basemapGallery = new BasemapGallery({
view: view,
container: document.createElement("div")
// Create an Expand instance and set the content
// property to the DOM node of the basemap gallery widget
const bgExpand = new Expand({
view: view,
content: basemapGallery
//Area Measurement
const measurementWidget = new AreaMeasurement3D({
view: view
const areaExpand = new Expand({
view: view,
content: measurementWidget
const lineOfSight = new LineOfSight({
view: view
const lineOfSightExpand = new Expand({
view: view,
content: lineOfSight
// LayerList
const layerList = new LayerList({
view: view
// Use an Esri icon font to represent the content inside
// of the Expand widget
const layerListExpand = new Expand({
expandIconClass: "esri-icon-layer-list",
view: view,
content: layerList
const legend = new Legend({
view: view
const legendExpand = new Expand({
expandIconClass: "esri-icon-legend",
view: view,
content: legend
const compass = new Compass({
view: view
const compassExpand = new Expand({
view: view,
content: compass
view.ui.add([bgExpand, areaExpand, lineOfSightExpand, layerListExpand, legendExpand, compassExpand], "top-right");
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
My Result:
I need my widget to include multiple widgets within, how to achieve that?
This is my goal widget. Mine should be expandable like this with multiple widgets within.
ReneRubalcava
Esri Frequent Contributor
You should remove your api key from your snippet.
You can probably accomplish what you want to do with Calcite components.
Here is a tutorial similar to what you want.
https://developers.arcgis.com/calcite-design-system/tutorials/create-a-mapping-app/
The action-bar also support a horizontal layout.
https://developers.arcgis.com/calcite-design-system/components/action-bar/
The calcite tutorials and documentation should help you accomplish what you're trying to do.
tippu_ks
Thank you, will check this out
