Need help to changing ESRI base map to ArcServer Base map
1563
05-09-2013 01:28 PM
GyeyoungChoi
Hello,
I was working with a sample
http://help.arcgis.com/en/webapi/javascript/arcgis/jssamples/find_map_datagrid.html
but for my school project I have to use ArcServer base map so I tried but did not work so far.
Any one can tell me what did I do wrong please?
Thank you,
Jack
Want to change from
function init() {
        dojo.connect(grid, "onRowClick", onRowClickHandler);
        center = [-83.266, 42.568];
        zoom = 11;
        map = new esri.Map("map", {
          basemap: "streets",
          center: center,
          zoom: zoom
        //Create Find Task using the URL of the map service to search
        findTask = new esri.tasks.FindTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/TaxParcel/TaxParcelQuery/MapServer/");
        dojo.connect(map, "onLoad", function() {
          //Create the find parameters
          findParams = new esri.tasks.FindParameters();
          findParams.returnGeometry = true;
          findParams.layerIds = [0];
          findParams.searchFields = ["OWNERNME1","OWNERNME2"];
          findParams.outSpatialReference = map.spatialReference;
          console.log("find sr: ", findParams.outSpatialReference);
TO
function init() {
  var initExtent = new esri.geometry.Extent({"xmin":1076363,"ymin":3109863,"xmax":1084228,"ymax":3113693,"spatialReference":{"wkid":32139}});
 map = new esri.Map("map",{
          infoWindow:popup,
          extent:initExtent,logo: false,
    zoom: 2,
          sliderStyle: "large"
        //dojo.connect(map,"onLoad",mapReady);
 var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://localhost:6080/arcgis/rest/services/COR/basemap/MapServer");
        map.addLayer(basemap);
        findTask = new esri.tasks.FindTask("http://localhost:6080/arcgis/rest/services/COR/intmap/MapServer");
          findParams.layerIds = [0,1,2,3];
          findParams.searchFields = ["Number","Name","Abbrev"];
The server is working fine and also without changing basemap findtask is working as well.
ShreyasVakil
There are 2 things I can point out by looking at your code :
1. you have used a popup to define map's infoWindow property, but never created the popup in your code.
2. there can be some issues with extent you have defined.
try the following for your init function:
 map = new esri.Map("map");
  var baseMapLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://localhost:6080/arcgis/rest/services/COR/basemap/MapServer");
        map.addLayer(baseMapLayer);
keep the map as simple as possible at first and check if you see the basemap and once you get your basemap to work, slowly start adding more properties to it.
Let me know if it helps.
GyeyoungChoi
Thanks Shreyas,
It worked! and a infoWindow is using for the popup but other code was not showing.
Thanks again
ShreyasVakil
Cool, I'm glad it worked!!
you can mark this as answered for others to see.
