Need help | Feature editor : Unable to implement drag/drop functionality
819
06-17-2022 06:18 AM
jfmssupport
We are using ESRI JS API 4. x and   ESRI Enterprise 10.7 stack includes ArcGIS Desktop and Server. We have developed a web application using ESRI JS  API and type script.
Goal is to develop an editor which perform all GIS operations (add/update/modify/move/delete) .
Data: All data is in feature layer format
What we tried:  Followed ESRI samples and developed a standard feature editor to add/update/delete some point records in our application.
Using the editor, it is possible to add/delete records, but in the case of the 'drag' event, the desired point cannot move and update Lat/Lon values.
Code: We followed ESRI feature editor code.
Any help/example would be great for that.
I am looking for examples that will show drag/drop points using the feature editor.
jfmssupport
Based on API documentation looks like the 'drag feature' using 'Feature editor' is not supported; is that correct?
If not, then what should be the alternative approach for that?
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Editor-UpdateWorkflow.htm...
