Nearest feature to a point?
1747
06-15-2010 01:12 AM
sunilm
Hi All,
I want nearest feature to the point(on map click) in all layers?
Thanks in Advance
Sunil
sunilm
Hi Adam,
Thanks for the reply,
Here it takes two points as input means do we need to check this for every feature in the layer(point layer).
What about incase of Line or Polygon feature class(layer). How can we find it out?
nicogis
You can create (with 10 version) a rest soe
http://proceedings.esri.com/library/userconf/devsummit10/papers/tech/extending_ags_services_using_.n...
and on server work with spatial index (every square have list of ids contained) then you try nearest from ids in square.
BillDaigle
You could publish a geoprocessing toolbox using the "Generate Near Table" tool.  This worked for us but required an upgrade to ArcGIS Server Advanced Edition.
GaneshSolai_Sambandam
Hi william
Can you post some code snippets for this, please? this would help lot of other people who wanted to use your code.
Regards
Ganesh
