Navtool bar
3584
6
09-11-2014 08:54 PM
RichardMoussopo
I have this code for the Zoom in function and it does not work.
//ToolBar
        navToolbar = new Navigation(map);
        on(navToolbar, "onExtentHistoryChange", extentHistoryChangeHandler);
        registry.byId("zoomin").on("click", function () {
            navToolbar.activate(Navigation.ZOOM_IN);
I have all the references...any idea?
JakeSkinner
Esri Esteemed Contributor
Hi Richard,
It may help to post all of your code (JavaScript and HTML) if possible.
RichardMoussopo
here is my html
<!--Toolbar-->
        <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'" style="background: #efefef;">
            <!--Tools-->
            <div id="navToolbar" data-dojo-type="dijit/Toolbar" style="width: 960px; margin: 0 auto; padding: 0;">
                <div data-dojo-type="dijit/form/Button" id="zoomin" data-dojo-props="iconClass:'zoominIcon'" title="Zoom In"></div>
                <div data-dojo-type="dijit/form/Button" id="zoomout" data-dojo-props="iconClass:'zoomoutIcon'" title="Zoom Out"></div>
                <div data-dojo-type="dijit/form/Button" id="pan" data-dojo-props="iconClass:'panIcon'" title="Pan"></div>
                <div data-dojo-type="dijit/form/Button" id="zoomfullext" data-dojo-props="iconClass:'zoomfullextIcon'" title="Full Extent"></div>
                <div data-dojo-type="dijit/form/Button" id="zoomprev" data-dojo-props="iconClass:'zoomprevIcon'" title="Previous Extent"></div>
                <div data-dojo-type="dijit/form/Button" id="zoomnext" data-dojo-props="iconClass:'zoomnextIcon'" title="Next Extent"></div>
                <div data-dojo-type="dijit/form/Button" id="saveMap" data-dojo-props="iconClass:'saveMapIcon'" title="Export Map"></div>
                <div data-dojo-type="dijit/form/Button" id="print" data-dojo-props="iconClass:'deactivateIcon'" title="Print Map"></div>
                <div data-dojo-type="dijit/form/Button" id="identify" data-dojo-props="iconClass:'identifyIcon'" title="Identify"></div>
                <div data-dojo-type="dijit/form/Button" id="intersection" data-dojo-props="iconClass:'intersectionIcon'" title="Roads Intersection"
                     onclick="dialogIntersection.show();"></div>
                <div data-dojo-type="dijit/form/Button" id="removeGraphic" data-dojo-props="iconClass:'removeGraphicIcon'" title="Remove Graphics" onclick="removeGraphic();"></div>
                <div data-dojo-type="dijit/form/Button" id="measure" data-dojo-props="iconClass:'measureIcon'" title="Measure"
                      onclick="(measureDialog.open) ? measureDialog.hide() : measureDialog.show();"></div>
                <!--About -->
                <div id="About" style="float: right;">
                    <div data-dojo-type="dijit/form/Button" id="AbouttheApp" data-dojo-props="iconClass:'aboutAppIcon'" onclick="DialogAboutApp.show();">About</div>
                </div>
            </div>
        </div>
and the Javascript
dojo.require("esri.dijit.Measurement");
dojo.require("dijit/form/CheckBox");
var dojoConfig = {
    parseOnLoad: true
var measureDialog = null;
var measurement = null;
var wgs84;
var map;
var loading;
require([
  "esri/map",
  "esri/arcgis/utils",
  "esri/toolbars/navigation",
  "esri/dijit/Measurement",
  "dijit/registry",
  "dojo/on",
  "dojo/parser",
  "esri/tasks/query",
  "esri/layers/FeatureLayer", "esri/dijit/Legend",
  "esri/dijit/Geocoder",
  "dojo/store/Memory",
  "dojo/_base/array",
  "dojo/_base/lang",
  "esri/request",
  "dojo/json",
  "dijit/layout/BorderContainer",
  "dijit/layout/ContentPane",
  "dijit/form/Button",
  "dijit/form/ComboBox",
  "dojo/domReady!"
], function  (
  Map, utils, Navigation, Measurement, registry, on, parser, Query, FeatureLayer, Legend, Geocoder, Memory, array, lang, esriRequest, json
    //Define Fairfield Own Base map
    //Define projection and start extent
    wgs84 = new esri.SpatialReference({ wkid: 3857 });
    startExtent = new esri.geometry.Extent(-9222914.374, 4857710.818, -9154122.569, 4802412.791, wgs84);
    // Create map
    var navToolbar;
    map = new esri.Map("map", { extent: startExtent, nav: false, slider: true, logo:false });
    //Need to define their Own proxi for the printing functionalities.
    esri.config.defaults.io.proxyUrl = "/proxy";
    esri.config.defaults.io.alwaysUseProxy = false;
    //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications
    esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
    // +++ ADD MAP LAYERS:
    // SPECIFY THE MAP SERVICE
    countyMapLayer = new esri.layers.ArcGISDynamicMapServiceLayer(".../MapServer");  //20140612
   // printMapLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://" + theHost + "/webadaptor/rest/services/Flex/20140616_WebPrint/MapServer");
    // Valid values are png | png8 | png24 | png32 | jpg | pdf | bmp | gif | svg
    countyMapLayer.setImageFormat("jpg");
    // ADD THE MAP SERVICE
    function init() {
        //parser.parse();
        loading = dojo.byId("loadingImg");
        map.addLayer(countyMapLayer);
        dojo.connect(map, "onUpdateStart", showLoading);
        dojo.connect(map, "onUpdateEnd", hideLoading);
        //Legend
        var legendLayers = [];
        var quakeLayer = new ArcGISDynamicMapServiceLayer(".../MapServer", {
        legendLayers.push({ layer: quakeLayer, title: 'Data' });
        var Utilities = new ArcGISDynamicMapServiceLayer("...MapServer", {
        map.on('layers-add-result', function () {
            var legend = new Legend({
                map: map,
                layerInfos: legendLayers
            }, "legendDiv");
            legend.startup();
        legendLayers.push({ layer: Utilities, title: "Utilities" });
        map.addLayers([Utilities, quakeLayer]);
            //add check boxes
            arrayUtils.forEach(legendLayers, function (layer) {
                var layerName = layer.title;
                var checkBox = new CheckBox({
                    name: "checkBox" + layer.layer.id,
                    value: layer.layer.id,
                    checked: layer.layer.visible
                checkBox.on("change", function () {
                    var targetLayer = map.getLayer(this.value);
                    targetLayer.setVisibility(!targetLayer.visible);
                    this.checked = targetLayer.visible;
                //add the check box and label to the toc
                domConstruct.place(checkBox.domNode, dom.byId("toggle"), "after");
                var checkLabel = domConstruct.create('label', {
                    'for': checkBox.name,
                    innerHTML: layerName
                }, checkBox.domNode, "after");
                domConstruct.place("<br />", checkLabel, "after");
        //measurement
        try {
            measureDialog = dijit.byId("dialogMeasurement");
            measurement = new esri.dijit.Measurement({
                map: map
            }, dojo.byId('measurementDiv'));
            measurement.startup();
            measureDialog.startup();
        catch (ex) {
            alert(ex.toString());
        function removeGraphic() {
            alert("No grpahic found on the map");
        //ToolBar
RichardMoussopo
I want to also add that the Legend also does not seem to work, same with the measurement too but about the measurement tool, it does work except that it behave weird in such the drawing starts far from the cursor position.
JakeSkinner
Hi Richard,
It looks like you are trying to combine legacy code with the AMD code.  Below is an example that contains a legend, measurement widget, basemap gallery, and a check-box to turn on/off each layer.  I would recommend building off of this to get the app you are looking for.
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <!--The viewport meta tag is used to improve the presentation and behavior of the samples
    on iOS devices-->
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title>Sample Map</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/tundra/tundra.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
  <style>
    html, body {
      height: 97%;
      width: 98%;
      margin: 1%;
    #rightPane {
      width: 30%;
    #pane1 {
      border: solid #97DCF2 1px;
    #header{
      border: solid #C0C0C0 2px;
      background-color:#C0C0C0
    #HomeButton {
      position: absolute;
      top: 98px;
      left: 26px;
      z-index: 50;
    #legendPane {
    #titlePane{
        width:240px;
      .claro .dijitTitlePaneTitle {
        background: #fff;
        font-weight:600;
        border: none;
        border-bottom:solid 1px #29201A;
        border-top:solid 1px #29201A;
      .claro .dijitTitlePaneTitleHover {
        background:#eee;
      .claro .dijitTitlePaneTitleActive {
        background:#808775;
      .claro .dijitTitlePaneContentOuter {
        border-right: none;
        border-bottom: none;
        border-left: none;
    .zoominIcon {
        background-image: url(images/nav_zoomin.png);
        width: 16px;
        height: 16px;
      .zoomoutIcon {
        background-image: url(images/nav_zoomout.png);
        width: 16px;
        height: 16px;
      .zoomfullextIcon {
        background-image: url(images/nav_fullextent.png);
        width: 16px;
        height: 16px;
      .zoomprevIcon {
        background-image: url(images/nav_previous.png);
        width: 16px;
        height: 16px;
      .zoomnextIcon {
        background-image: url(images/nav_next.png);
        width: 16px;
        height: 16px;
      .panIcon {
        background-image: url(images/nav_pan.png);
        width: 16px;
        height: 16px;
      .deactivateIcon {
        background-image: url(images/nav_decline.png);
        width: 16px;
        height: 16px;
  </style>
  <script src="http://js.arcgis.com/3.10/"></script>
  <script>
    var map;
    require([
      "dojo/parser", "esri/map", "esri/dijit/HomeButton", "esri/toolbars/navigation",
      "esri/layers/FeatureLayer", "dojo/on", "dojo/dom", "dijit/registry",
      "dojo/dom-construct", "esri/dijit/Legend", "dojo/_base/array", "esri/dijit/Measurement",
      "dijit/form/CheckBox",  "esri/dijit/BasemapGallery", "esri/dijit/Geocoder",
      "esri/graphic", "esri/symbols/SimpleMarkerSymbol", "esri/geometry/screenUtils", "dijit/Toolbar","dijit/form/Button",
      "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/layout/AccordionContainer", "dojo/domReady!"
    ], function(
      parser, Map, HomeButton, Navigation,
      FeatureLayer, on, dom, registry,
      domConstruct, Legend, array, Measurement,
      CheckBox, BasemapGallery, Geocoder,
      Graphic, SimpleMarkerSymbol, screenUtils, Toolbar, Button,
      BorderContainer, ContentPane, AccordionContainer
      parser.parse();
      console.log(registry.byId("zoomin"));
      //Create the map
      var map = new Map("map", {
        center: [-80.734, 28.297],
        zoom: 10,
        basemap: "topo"
      //Add a home button
      var home = new HomeButton({
        map:map
      }, "HomeButton");
      home.startup();
      //Add Feature Layers
      var cities = new FeatureLayer(
          "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map...", {
          mode: FeatureLayer.MODE_ONDEMAND,
          outFields: ["*"]
      var rivers = new FeatureLayer(
          outFields: ["*"]
      var states = new FeatureLayer(
          opacity: 0.5,
          outFields: ["*"]
            //add the legend
      map.on("layers-add-result", function (evt) {
          var layerInfo = array.map(evt.layers, function (layer,
          index) {
              return {
                  layer: layer.layer,
                  title: layer.layer.name
          if (layerInfo.length > 0) {
              var legendDijit = new Legend({
                  map: map,
                  layerInfos: layerInfo
              }, "legendDiv");
              legendDijit.startup();
                //add check boxes
          array.forEach(layerInfo,
          function (layer) {
                  checked: layer.layer.visible,
                  onChange: function (evt) {
                      var clayer = map.getLayer(this.value);
                      clayer.setVisibility(!clayer.visible);
                      this.checked = clayer.visible;
                    //add the check box and label to the TOC
              domConstruct.place(checkBox.domNode, "toggle",
                  "after");
                  "after");
      map.addLayers([states, rivers, cities]);
      //Create the Basemap
      var basemapGallery = new BasemapGallery({
        showArcGISBasemaps: true,
        map: map
      }, "basemapGallery");
      basemapGallery.startup();
      basemapGallery.on("error", function(msg) {
        console.log("basemap gallery error:  ", msg);
      registry.byId("zoomout").on("click", function () {
        navToolbar.activate(Navigation.ZOOM_OUT);
      registry.byId("zoomfullext").on("click", function () {
        navToolbar.zoomToFullExtent();
      registry.byId("zoomprev").on("click", function () {
        navToolbar.zoomToPrevExtent();
      registry.byId("zoomnext").on("click", function () {
        navToolbar.zoomToNextExtent();
      registry.byId("pan").on("click", function () {
        navToolbar.activate(Navigation.PAN);
      registry.byId("deactivate").on("click", function () {
        navToolbar.deactivate();
      function extentHistoryChangeHandler () {
        registry.byId("zoomprev").disabled = navToolbar.isFirstExtent();
        registry.byId("zoomnext").disabled = navToolbar.isLastExtent();
      var measurement = new Measurement({
          map: map
        }, dom.byId("measurementDiv"));
  </script>
</head>
<body class="tundra">
<div id="content"
     data-dojo-type="dijit/layout/BorderContainer"
     data-dojo-props="design:'headline', gutters:true"
     style="width: 100%; height: 100%; margin: 0;">
  <div id="header"
       data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'">
      <strong>Sample Map</strong>
      <div id="navToolbar" data-dojo-type="dijit/Toolbar">
        <div data-dojo-type="dijit/form/Button" id="zoomin"  data-dojo-props="iconClass:'zoominIcon'">Zoom In</div>
        <div data-dojo-type="dijit/form/Button" id="zoomout" data-dojo-props="iconClass:'zoomoutIcon'">Zoom Out</div>
        <div data-dojo-type="dijit/form/Button" id="zoomfullext" data-dojo-props="iconClass:'zoomfullextIcon'">Full Extent</div>
        <div data-dojo-type="dijit/form/Button" id="zoomprev" data-dojo-props="iconClass:'zoomprevIcon'">Prev Extent</div>
        <div data-dojo-type="dijit/form/Button" id="zoomnext" data-dojo-props="iconClass:'zoomnextIcon'">Next Extent</div>
        <div data-dojo-type="dijit/form/Button" id="pan" data-dojo-props="iconClass:'panIcon'">Pan</div>
        <div data-dojo-type="dijit/form/Button" id="deactivate" data-dojo-props="iconClass:'deactivateIcon'">Deactivate</div>
      </div>
  </div>
  <div id="rightPane"
       data-dojo-type="dijit/layout/ContentPane"
       data-dojo-props="region:'left'">
    <div data-dojo-type="dijit/layout/AccordionContainer">
      <div data-dojo-type="dijit/layout/ContentPane" id="pane1"
           data-dojo-props="title:'Base Maps', selected:false">
        <div id="basemapGallery"></div>
      </div>
           data-dojo-props="title:'Layers'">
          <span style="padding: 10px 0;">Click to toggle each layer on or off</span>
          <div id="toggle" style="padding: 2px 2px;"></div>
      </div>
      <div data-dojo-type="dijit/layout/ContentPane" id="legendPane"
           data-dojo-props="title:'Legend', selected:true">
        <div id="legendDiv"></div>
      </div>
    </div>
  </div>
  <div id="map"
       data-dojo-props="region:'center'"
       style="overflow:hidden;">
       <div style="position:absolute; right:20px; top:10px; z-Index:999;">
          <div id="titlePane" data-dojo-type="dijit/TitlePane" data-dojo-props="title:'Measurement', closable:'false', open:'false'">
            <div id="measurementDiv"></div>
            <span style="font-size:smaller;padding:5px 5px;">Press <b>CTRL</b> to enable snapping.</span>
          </div>
       </div>
  <div id="HomeButton"></div>
  </div>
</div>
</body>
</html>
RichardMoussopo
Hi Jack,
Thank you, this is exactly what I was looking for. Thank you.
Also, I've you ever worked with dojo/floatingPane? Trying to implement that declaratively...I have the css setup but on button click, the floating won't show up...
Thank you again
JakeSkinner
I would recommend starting a new thread for that question, and post the code you are using.  Also, if you can, mark this thread as 'answered' to help other users in the community.
