Navigation toolbar AMD confusion
3475
01-23-2014 04:53 AM
markrobey
Converting a simplified version of the navToolbar sample has caused me some confusion in terms of the AMD navigation module.
In the script below the zoomfullextent, zoomnext and zoomprev buttons all work as expected. However, the zoomin and zoomout buttons do not work. I see in other people's examples that they use:
navToolbar.activate(esri.toolbars.Navigation.ZOOM_IN)
This does indeed work (if I substitute it into the code below). But why does
navToolbar.activate(ZOOM_IN)    not work?
Looking at the documentation it seems like it should work as activate() and zoomToFullExtent() are both methods of the Navigation object.
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Navigation toolbar</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css"/>
    <style type="text/css">
      @import "http://js.arcgis.com/3.8/js/dojo/dijit/themes/claro/claro.css";
      .zoominIcon { background-image:url(images/zoomin16_tiny.png); width:16px; height:16px; }
      .zoomoutIcon { background-image:url(images/zoomout16.png); width:16px; height:16px; }
      .zoomfullextIcon { background-image:url(images/fullextent32_tiny.png); width:16px; height:16px; }
      .zoomprevIcon { background-image:url(images/previous16.png); width:16px; height:16px; }
      .zoomnextIcon { background-image:url(images/next16.png); width:16px; height:16px; }
      .panIcon { background-image:url(pan16_tiny.png); width:16px; height:16px; }
    </style>
    <script type="text/javascript" src="http://js.arcgis.com/3.8/"
        data-dojo-config="async: true"></script>
    <script type="text/javascript">
        var navToolbar;
        require([
        "dojo/parser",
        "esri/map",
        "esri/toolbars/navigation",
        "dijit/form/Button",
        "dijit/Toolbar",
        "dojo/domReady!"
        function (parser, Map, Navigation) {
            parser.parse();
            map = new Map("map", {
                basemap: "satellite",
                center: [-56.953, 57.472],
                zoom: 3
            navToolbar = new Navigation(map);
    </script>
  </head>
  <body class="claro">
    <div id="navToolbar" data-dojo-type="dijit/Toolbar">
      <button type="button" data-dojo-type="dijit/form/Button" id="zoomin" data-dojo-props="iconClass:'zoominIcon'">
        <script type="dojo/on" data-dojo-event="click">
            navToolbar.activate(ZOOM_IN);
        </script>
        Zoom In
      </button>
      <button type="button" data-dojo-type="dijit/form/Button" id="zoomout" data-dojo-props="iconClass:'zoomoutIcon'">
            navToolbar.activate(ZOOM_OUT);
        </script>
        Zoom Out
      </button>
      <button type="button" data-dojo-type="dijit/form/Button" id="zoomfullext" data-dojo-props="iconClass:'zoomfullextIcon'">
            navToolbar.zoomToFullExtent();
        </script>
        Full Extent
      </button>
      <button type="button" data-dojo-type="dijit/form/Button" id="zoomprev" data-dojo-props="iconClass:'zoomprevIcon'">
            navToolbar.zoomToPrevExtent();
        </script>
        Prev Extent
      </button>
      <button type="button" data-dojo-type="dijit/form/Button" id="zoomnext" data-dojo-props="iconClass:'zoomnextIcon'">
            navToolbar.zoomToNextExtent();
        </script>
        Next Extent
      </button>
      <button type="button" data-dojo-type="dijit/form/Button" id="pan" data-dojo-props="iconClass:'panIcon'">
            navToolbar.activate(PAN);
        </script>
        Pan
      </button>
    </div>
    <div id="map" style="width:100%; height:512px;"></div>
  </body>
</html>
JonathanUihlein
If you use the console to inspect "esri.toolbars.Navigation.ZOOM_IN", you'll see its actually a string (or constant, per the documentation you linked). The string value is "zoomin"
Proper Syntax:
navToolbar.activate(esri.toolbars.Navigation.ZOOM_IN);
This works as well:
navToolbar.activate("zoomin");
When you try to use:
ZOOM_IN is not defined (nor is it one of the expected strings), so logically it will not work.
JonathanUihlein
Proper Syntax:
This works as well:
markrobey
You're right, those do work. But what has me confused is that the doco says that the constant should be "ZOOM_IN"
https://developers.arcgis.com/en/javascript/jsapi/navigation-amd.html#activate
activate(navType)
Activates the toolbar for map navigation. Activating the toolbar overrides default map navigation.
Parameters:
<String> navType  Required  The navigation type. The Constants table lists valid navigation values.
Constants
Name Description
PAN Map is panned.
ZOOM_IN Map zooms in.
ZOOM_OUT Map zooms out.
markrobey
Forget that. Didn't read your reply properly.
Cheers,
Mark
JonathanUihlein
No problem! It tripped me up at first too, I promise.
I basically had to realize that 'ZOOM_IN' was the name of the constant, but not the value.
Additionally, the constant is a property of the esri.toolbars.Navigation object, justifying the need to reference the full-path.
For the record, I do agree that the documentation should probably make that a bit more clear
Make sure you mark the thread as 'answered' if you are completely satisfied.
markrobey
Yes, I was reading it as a value too.
