Nautical Miles Units for Measurement Tool
1888
04-08-2013 11:22 AM
WillMcClintock
Hello!
I am interested in setting the units for the measurement tool to "nautical miles" but this doesn't seem to be an option. Does anyone know if this is possible and/or if it is slated to come out with an upcoming release of the Javscript API?
DerekWicks1
Hi Will,
Just wondering if you or anybody else has figured out a solution on how to do this? I was about to post the exact same question.
Derek
WillMcClintock
Unfortunately not! Given the Ocean Initiative at Esri, I think we should push this through as a high priority. I'll see if I can get some movement through other channels.
-Will
JianHuang
Measurement widget already has �??Nautical Miles�?� built in. We just didn�??t expose it. In order to show it on the drop down menu, you just need to add a menu item. And the widget will handle all the conversions and book keeping work.
Here is the code snippet:
                 dojo.connect(measurement.distance, "onClick", function(){
                   if (this.checked) {
                     var nauticalMenuItem = new dijit.MenuItem({
                       label: "Nautical Miles",
                              onClick: function(){
                                measurement._switchUnit("Nautical Miles");
                     measurement.unit.dropDown.addChild(nauticalMenuItem);
That�??s all the code you need for distance measurement. In case you need the area measurement tool work with nautical miles as well, here is the code:
                //from acres to square nautical miles
                 measurement.unitDictionary["Square Nautical Miles"] = 0.001179874545293396;
                 dojo.connect(measurement.area, "onClick", function(){
                   if (this.checked) {
                     var nauticalAreaMenuItem = new dijit.MenuItem({
                       label: "Square Nautical Miles",
                                measurement._switchUnit("Square Nautical Miles");
                     measurement.unit.dropDown.addChild(nauticalAreaMenuItem);
DerekWicks1
Thanks Jian!
