My Webmap loads in arcgis sample box but it doesn't work when I transfer the code anywhere else!
2888
05-16-2016 09:21 AM
AntoinePerron
Hi everyone,
I,m pretty new to all of this. I am trying to export my html code to a website I am building from a GoDaddy template. (like a third-party application within the website). I found the perfect sample code in the Arcgis API for javaScript. I change the webmap ID to my webmap from Arcgis Online. But when I tried to download the code locally or export it to the website I am trying to build nothing seems to work!
I know there is something I am missing here but I can't figure what it is... Please Help!!
This is the sample code I am trying to use ArcGIS API for JavaScript Sandbox
RobertScheitlin__GISP
Antoine,
  Make sure that you download the source code and not just copy it from the sandbox:
Click the link below to download. This sample uses a custom css file that you will not have on your system unless you download the source code and deploy it to your web server.
http://www.arcgis.com/sharing/rest/content/items/a24ab8c9058245b187c939deac35deb9/data
AntoinePerron
How can i integrate the css code, after i download it? Do I just copy it in a <style> bracket in the html page code?
If you look at the code there is already a line in the html for this:
<link rel="stylesheet" href="css/layout.css">
That means you just need the css folder at the same folder level as your html code.
