Multiple layers info in one popup window
1995
07-25-2017 08:24 AM
ManjariGoyal
I am trying to get the popup info from multiple layers in one info window, including address, lat and long. I am not able to add address, lat long info in the same window . Also, when I click on the map it doesn’t remove the old info from the popup and keeps adding the new one. Attached is the JavaScript and the screenshot for your reference. Any help is appreciated.
Thanks
Tags (1)
JohnGravois
after downloading and unzipping your sample and commenting out the <link> tags to .css files that weren't available, <script> tag for the TOC widget that was unavailable and references to the widget within the actual JavaScript i was finally able to get it to run locally and was not able to reproduce the error you describe.
each time i clicked on the map, a single address and lat/long coordinate pair were displayed.
when creating future posts, please consider using something like jsbin/codepen or jsfiddle to share your simplified reproducible test case so that folks can dedicate more time to debugging and less to set up.
