Multiple LayerLists In Web App
7155
15
09-05-2019 11:39 AM
RichardRhone
Is it possible to have more than one layerlist in one web app. I would like to add another layerlist where i can have only some of the layers visible in layerList1 and other layers visible in layerList2
RichardRhone
Thanks Robert.
However, It doesn't work if I add the layerList to a container
 var otherLayer = new LayerList({  view: view  , container: "oRisk" });
I gather I would have to edit the following?
 var lis = query('li[aria-labelledby $= "__title"]', otherRisksLayer.domNode);
not quite sure to what though. Any advise?
RobertScheitlin__GISP
Richard,
   You have to query the list container node.
var lis = query('li[aria-labelledby $= "__title"]', "oRisk");
RichardRhone
That doesn't seems to work:
//configure customer layer list for other risks
var otherLayer = new LayerList({ view: view, container: "oRisk", listItemCreatedFunction: function (event) { item = event.item; item.panel = { content: "legend" }; }});
view.ui.add(otherLayer, "manual");
//workaround for making sure layerlist is ready
watchUtils.when(otherLayer, 'operationalItems.length', function(){
console.log("in function");
console.log("LIS ", lis);
lis.map(function(li)
console.log("in li ", li);
Results:
Only 2 of 3 logs show
Richard,
Seems like a timing issue.
      view.when(function () {
          view: view,
          container: "oRisk",
            item = event.item;
            item.panel = {
              content: "legend"
        watchUtils.when(otherLayer, 'operationalItems.length', function () {
          setTimeout(function () {
            var lis = query('li[aria-labelledby $= "__title"]', 'oRisk');
            console.info(lis);
            lis.map(function (li) {
              if (li.innerText === "San Francisco") {
                domStyle.set(li, "display", "none");
              if (li.innerText === "Growth Potential") {
          }, 0)
RichardRhone
Thanks. That worked
TamiaRudnicky
  I am trying to modify the multiple layerList code for use with the latest ArcGIS JavaScript api 4.15 and am not having much luck. I tried removing dojo query and domStyle and substituting vanilla javascript but got lost trying to capture the list and manipulate it.
  Has anyone successfully upgrade this code or can anyone help me with this?
Thanks.
