Multiple labelplacements in labelclass
994
04-28-2020 07:26 AM
EricRydgren
I am using ArcGis 4.11, and I am having trouble showing labels when they are close to eachother.
Is there any way to get the labelplacement on a labelclass to "check if there's room for the label, and if not, select another label placement"
If labelplacement "center-right" is not avilable, set labelplacement to "above-right", and so on.
I would like to be able to show all my labels, even if they are close to eachother.
Any suggestions on how to make this happen?
Thank you in advance.
Tags (1)
VictorTey
Hi you may be able to use text symbol to give you more control over the label placement.
TextSymbol | ArcGIS API for JavaScript 4.15
"Text symbols can also be used to define the symbol property of Graphic if the geometry type is Point or Multipoint."
