multiple ArcGISDynamicMapServiceLayer IdentifyTask
19513
12
06-04-2014 04:53 PM
ArowanaIndah
I'm using 'Display identify results in popup' sample and try to add 2 or 3 ArcGISDynamicMapServiceLayer. How do i configure the code so that the popup will show result of selected ArcGISDynamicMapServiceLayer.
Thank
<!DOCTYPE html>  <html>     <head>      <meta http-equiv="Content-Type" content="text/html; charset=utf-8">      <!--The viewport meta tag is used to improve the presentation and behavior of the samples         on iOS devices-->      <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">      <title>Identify with Popup</title>        <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css">      <style>        html, body, #map {          height:100%;          width:100%;          margin:0;          padding:0;        }      </style>        <script src="http://js.arcgis.com/3.9/"></script>      <script>        var map;          require([          "esri/map",          "esri/InfoTemplate",          "esri/layers/ArcGISDynamicMapServiceLayer",          "esri/symbols/SimpleFillSymbol",          "esri/symbols/SimpleLineSymbol",          "esri/tasks/IdentifyTask",          "esri/tasks/IdentifyParameters",          "esri/dijit/Popup",          "dojo/_base/array",          "esri/Color",          "dojo/dom-construct",          "dojo/domReady!"        ], function (          Map, InfoTemplate, ArcGISDynamicMapServiceLayer, SimpleFillSymbol,          SimpleLineSymbol, IdentifyTask, IdentifyParameters, Popup,          arrayUtils, Color, domConstruct        ) {            var identifyTask, identifyParams;            var popup = new Popup({            fillSymbol: new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,              new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,                new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25]))          }, domConstruct.create("div"));            map = new Map("map", {            basemap: "satellite",            center: [-83.275, 42.573],            zoom: 18,            infoWindow: popup          });            map.on("load", mapReady);            var parcelsURL = "http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/Parcels/MapServer";          map.addLayer(new ArcGISDynamicMapServiceLayer(parcelsURL,            { opacity: .55 }));            function mapReady () {            map.on("click", executeIdentifyTask);            //create identify tasks and setup parameters            identifyTask = new IdentifyTask(parcelsURL);              identifyParams = new IdentifyParameters();            identifyParams.tolerance = 3;            identifyParams.returnGeometry = true;            identifyParams.layerIds = [0, 2];            identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL;            identifyParams.width = map.width;            identifyParams.height = map.height;          }            function executeIdentifyTask (event) {            identifyParams.geometry = event.mapPoint;            identifyParams.mapExtent = map.extent;              var deferred = identifyTask              .execute(identifyParams)              .addCallback(function (response) {                // response is an array of identify result objects                // Let's return an array of features.                return arrayUtils.map(response, function (result) {                  var feature = result.feature;                  var layerName = result.layerName;                    feature.attributes.layerName = layerName;                  if (layerName === 'Tax Parcels') {                    var taxParcelTemplate = new InfoTemplate("",                      "${Postal Address} <br/> Owner of record: ${First Owner Name}");                    feature.setInfoTemplate(taxParcelTemplate);                  }                  else if (layerName === 'Building Footprints') {                    console.log(feature.attributes.PARCELID);                    var buildingFootprintTemplate = new InfoTemplate("",                      "Parcel ID: ${PARCELID}");                    feature.setInfoTemplate(buildingFootprintTemplate);                  }                  return feature;                });              });              // InfoWindow expects an array of features from each deferred            // object that you pass. If the response from the task execution            // above is not an array of features, then you need to add a callback            // like the one above to post-process the response and return an            // array of features.            map.infoWindow.setFeatures([deferred]);            map.infoWindow.show(event.mapPoint);          }        });      </script>    </head>        <body>      <div id="map"></div>    </body>    </html>
KenBuja
I'm using the 3.11 API and I've used this code with the services on 10.0 and 10.2 servers.
SamYoung1
Hey  Ken, We need to do exactly this type of thing here. I tried to copy and run your solution but it comes across with no formatting. Found an earlier sample that threw a css error. I recognize the last time you touched this was six months ago but is there any way I can get a functional copy. Thanks.
KenBuja
I've updated the formatting with it, although I don't know why it was stripped from the original reply.
