I am not sure if there are any examples. They are just methods and they have been documented very well.
But, If we are asking what kind of use-cases they can be used? Then, GeometryEngine can be used in lot of other cases where you want to find the relation between 2 geometries, or with the densify to increase the vertex on a geometry or clip, cut, difference and rotate methods you could modify a geometry.
